Single axle tractor with tri axel trailer
Discussion in 'Questions From New Drivers' started by lulzzors, Feb 24, 2014.
  1. lulzzors
    lulzzors Bobtail Member
    6
    Jun 6, 2012
    Alberta
    Is it legal to pull a tri axle 53' dry van with a single axle tractor unit? This would be for Canada.
    My company has never tried this before so I'm just a little skeptical about doing it. I've definitely never seen anyone else do it.
    Weight wise I'd be fine, about 19630 kg in the trailer. I'd likely need to slide the trailer axles but I'd still be legal.
  3. TripleSix
    133,587
    I don't think I've ever seen a single axle tractor in Canada. Even the yard dogs have twin screws. Should make for interesting conversations.
  4. lulzzors
    6
    Jun 6, 2012
    Alberta
    Well we have 3 of them, we only have 1 tandem and it use to pull this tri axle trailer across Canada weekly but it's doing another trip right now.
    We just don't haul enough weight to justify a tandem, well yet, they're getting tandem trailers now for us to use so we're ending up overweight sometimes with the single axle (the tandems don't slide on the trailer).
  5. HotH2o
    HotH2o Road Train Member
    4,100
    4,868
    Sep 23, 2012
    I assume by "single axle tractor" you mean single drive axle? Not illegal unless you exceed axle weight.
  6. 12 ga
    12 ga THE VIEW FROM MY OFFICE
    1,568
    1,789
    Oct 21, 2013
    Central Michigan
    He is talking about a single screw tractor pulling a three nine foot spreed trailer. I've seen lots of them over the years, just have the weight distributed correctly. 18K each I believe.
  7. PackRatTDI
    PackRatTDI Licensed to Ill
    14,765
    22,569
    Jul 15, 2006
    El Chuco, Tejas
    Sounds like a European setup.
  8. lulzzors
    6
    Jun 6, 2012
    Alberta
    I was looking into it today and I can't do it, well I shouldn't say I can't do it but I shouldn't do it.
    The truck is registered for 23,800 kg but the truck alone weights 9,778 kg, no idea what the trailer weighs but I'm already overweight with just the truck and product.
    I mentioned it today so they're either going to go and increase the weight that the truck is registered for, or just wait until next week or this weekend and I'll use our tandem volvo 780
    And yes, this truck is single drive axle. It's a peterbilt 382.
  9. The Admiral
    The Admiral Heavy Load Member
    894
    561
    Jul 18, 2010
    Akron,Ohio
    Back in the 70's there were a lot of single axle Chevy gas jobs running between Ohio and Chicago pulling 3 axle trailers. Owned 4 of them myself. And then there was Milton Baker King of The Chevrolets . At one time he had 17 Chevys leased to B&P. Sunday night on the Ohio Turnpike you could see us heading west to Chicago. We are not talking hot shots either we pulled 60K- 80K payload on a regular basis. Once in a while 100K+.
  10. dutchieinquebec
    dutchieinquebec Road Train Member
    1,282
    4,872
    Sep 30, 2012
    Granby.QC
    picture from
    hankstruckforum.com​
    Polyform of Granby Quebec, thanks Pascal Followed by its twin sister and same trailer.
    they use single axle trucks to transport matrasses
