Size vs weight when expediting
Discussion in 'Expediter and Hot Shot Trucking Forum' started by wl90.200, Mar 11, 2023.
  1. wl90.200
    wl90.200 Light Load Member
    52
    7
    Sep 22, 2022
    Q1) What the best for expediting
    Weight or size?
    for example cargo van is only 10ft length but can haul more lb
    16ft box truck on the other side has more space but less payload
    Q2) if my gvwr is 12,000 and my truck+ the load I’m carrying weight 9k. Would I need to use ELD? My truck is rated above 10k but my actual total weight is 9k. Do I still have to use ELD?
    Q3)when expediting, what should I go for? Cargo van or box trucks?
  3. jeffman164
    jeffman164 Medium Load Member
    631
    587
    Dec 4, 2012
    There is a web site called expeditorsonline that specializes in expediting. They will probably be to answer your questions more accurately.
    wl90.200 Thanks this.
  4. Ridgeline
    22,750
    123,943
    It is all based on your GVWR, nothing else.
    So yes you would have to log.
  5. wl90.200
    52
    7
    Sep 22, 2022
    Cargo van is limited with size and height but has higher payload capacity
    the same truck with 16ft box has less payload but more size
    Should I go for 16ft box truck Chevy express or Chevy express Van?
  6. jeffman164
    631
    587
    Dec 4, 2012
    All variables considered - If the 16ft box truck isn't dock high which I doubt, I would go with the van .
  7. wl90.200
    52
    7
    Sep 22, 2022
    It would be better mileage too
    Lite bug Thanks this.
