Sliding fifth wheel question
Discussion in 'Experienced Truckers' Advice' started by Still undecided, Aug 31, 2022.
  1. Still undecided
    Still undecided Heavy Load Member
    982
    1,218
    Aug 21, 2019
    I got a different truck at work this week and it's got a sliding fifth wheel that's all the way forward. The truck is a Cascadia daycab on a frame long enough to be a sleeper, and it takes even more room to maneuver than the T680 sleeper I had before it. Two of the other drivers have given me different advice on the position of the fifth wheel, one said it's in the position that makes it hardest to maneuver and the other said it's in the spot that makes it the easiest to maneuver. Where should it be to make it maneuver the easiest?
  3. Another Canadian driver
    Another Canadian driver Road Train Member
    1,181
    4,266
    Nov 14, 2021
    ALBERTA
    1-2 inches behind the middle of the tandem.
    1 hole behind.
    Depending on the distance between holes.
  4. Big Road Skateboard
    7,181
    40,706
    May 2, 2021
    If weight is no issue, furthest forward would maneuver easiest. Like ACD mentioned above if your loading max
  5. W923
    W923 Road Train Member
    1,424
    4,412
    Feb 28, 2022
    Further forward is better going forward but can mess with you going backwards…as you start the trailer heading one way it will actually go the other way briefly. It’s not really a big deal unless you’re trying to back down a narrow lane or something and make a small correction then you will notice it. I am also talking about having the fifth wheel close to 3 feet in front of the center of the tandem.
  6. snowwy
    snowwy Road Train Member
    20,612
    13,333
    Jul 6, 2009
    The shorter your over all length. The easier to turn.
    Mine is quite a bit north of center. But that's how it's setup.
    MACK E-6 and Still undecided Thank this.
  7. T2012
    T2012 Bobtail Member
    24
    33
    Aug 23, 2022
    I've always set mine all the way back as soon as I get a tractor, and that's where it stays as long as I'm in it.
    If you get used to and comfortable with a certain setting, I'd say leave it there and forget about it.
    The setting that's best for you is the one you're used to, the one you've made 1000 turns and backs with.
    But if you have it all the way forward, don't try any real tight u-turns in a drop lot.
  8. shmelk
    shmelk Bobtail Member
    15
    12
    Sep 1, 2022
    Is there an advantage to having it all the way back?
  9. silverspur
    silverspur Road Train Member
    1,766
    8,207
    Sep 26, 2012
    If it's all the way back you are less likely to crunch your fairings on a tight turn.
  10. mustang190
    mustang190 Road Train Member
    2,894
    6,258
    Jan 18, 2011
    Florida Panhandle
    I always keep mine all the way back.
    Makes for a better ride.
  11. mustang190
    2,894
    6,258
    Jan 18, 2011
    Florida Panhandle
    Makes a better ride, looks good and if you need to move some weight off your drives, slide your seat forward a couple of notches. :salute:
