Sliding Tandems vs Spread
Discussion in 'Flatbed Trucking Forum' started by Big Road Skateboard, Jun 27, 2023.
  1. Big Road Skateboard
    7,182
    40,723
    May 2, 2021
    Y'all that have run both. I know the difference in weights, but how does this work out real world?
    If you pay attention to loading is it a big deal?
    With trailer prices dropping I've considered picking one up. Would think with adding a Riggt Weigh it wouldn't be a big deal.
    cke, D.Tibbitt and singlescrewshaker Thank this.
  3. Mnmover99
    Mnmover99 Light Load Member
    248
    344
    Oct 22, 2022
    If you can slide axles on a spread that would work fine.
    cke, Bean Jr. and singlescrewshaker Thank this.
  4. Ruthless
    Ruthless Road Train Member
    9,199
    91,384
    Aug 28, 2010
    The City.
    In my opinion, it depends on where you are, where you go, and what you’re doing.
    There’s a few states that give you more than 34,000 on a closed tandem, which will help if you’re trying to make gross and have a hood.
    cke, exhausted379, Oxbow and 4 others Thank this.
  5. Big Road Skateboard
    7,182
    40,723
    May 2, 2021
    Didn't know that. I try to stay north of 40 and west of 29/49. No California. Had a humdinger of a load headed to Alaska ready to book today.
    I thought BC allowed 9100 kilos on each axle of a spread. I was mistaken, and it's 9100 gross on my spread
    cke, Oxbow, beastr123 and 2 others Thank this.
  6. Razororange
    Razororange Road Train Member
    2,724
    25,905
    Dec 20, 2011
    Milwaukee, WI
    If you want something like that you could look at a sliding rear axle spread. Run as a closed tandem to go into western Canada or save on tire wear. Then open it up to a spread when you get into the US or if you need to go heavy in the back. Best of both options.
    cke, Oxbow, Ruthless and 3 others Thank this.
  7. Big Road Skateboard
    7,182
    40,723
    May 2, 2021
    If I can find one at the right price I'll definitely look. Just seems the closed tandems are much less desireable, therefore cheap.
  8. Razororange
    2,724
    25,905
    Dec 20, 2011
    Milwaukee, WI
    Yea for sure. I mean either way 80K is your max. Just have to do more thinking to be legal on axles.
  9. Kshaw0960
    Kshaw0960 Road Train Member
    1,581
    5,025
    Jun 17, 2018
    My opinion that’s worth less than salt, I would consider a closed tandem if it’s much cheaper than a spread if it’s an aero truck and not a hood. It’s impossible for me to get over 10,400 on steers unless the trailer is ridiculously forward on me 5th wheel slide. If you have an aero truck I think it will be ok. The only thing I would do is keep scaling one item loads (steel bars, coils) until you nail down the exact center. I think the only problems will come with heavier loads that extend off the back of the trailer.
  10. Big Road Skateboard
    7,182
    40,723
    May 2, 2021
    I'm heavy up front full of fuel if that makes any difference. Center of fifth wheel is on the front edge of my rear drives. Here's an empty scale ticket, along with a couple of average loaded tickets. When i have a load centered on my trailer, the #'s on these scale tickets are pretty close. Most all of my fuel weight goes onto my steers, and I hold 300 gallons
  11. Bean Jr.
    Bean Jr. Road Train Member
    5,573
    9,930
    Mar 30, 2014
    Having the spread is a no brainer, unless two coils and the weight difference is huge. Then I have start thinking. Until I moved my fifth wheel, I might have scaled 2 loads in 5 years
