Slow Air Leak Hi/Lo Range Selector
Discussion in 'Ask An Owner Operator' started by ChevyCam, Feb 21, 2020.
  1. ChevyCam
    ChevyCam Light Load Member
    269
    401
    Mar 4, 2018
    Hey guys, hoping I can get some insight from you experienced O/O. My truck is a 96 International 9400 with N14/Eaton 10spd.
    Today I pulled the dog house/floor pan and found the air leak that I've been hearing. The leak is coming from the one of the Hi/Lo Range selector lines where its fits into its o-ring and fitting. The fitting is screwed in tight to the K3245 air module.
    When you wiggle the air line the leak somewhat goes away and comes right back when you take tension off the air line.
    The truck runs and drives fine, no issue with shifting or range selection.
    Is this just as simple as swapping the o-ring and/or fitting? Is this a good time to go ahead and replace the Hi/Lo shifter lines completely for good measure.
    This is a picture of what I found.
  3. Oscar the KW
    Oscar the KW Going Tarpless
    12,246
    28,116
    May 19, 2011
    You can try just cutting the end of the line off. Sometimes they will leak where the line is compressed in the fitting.
  4. ChevyCam
    269
    401
    Mar 4, 2018
    So pull line from fitting, cut off end, push back into fitting and see if that does the trick. Ill grab a pack of orings in the am and try this.
  5. Oscar the KW
    12,246
    28,116
    May 19, 2011
    Yes, that will usually take care of it. If not, you’ll need to replace the fitting.
    ChevyCam Thanks this.
  6. ChevyCam
    269
    401
    Mar 4, 2018
    Thank you sir.
  7. danny23tx
    danny23tx Road Train Member
    1,494
    2,324
    Feb 16, 2016
    Austin,Tx
    I replaced both of mine , it was like a $8 fix .
  8. ChevyCam
    269
    401
    Mar 4, 2018
    New lines and fittings total of $20 bucks. Thanks for the input guys.
