Slow to start - W900
Discussion in 'Ask An Owner Operator' started by lantern756, Mar 30, 2018.
  1. lantern756
    lantern756 Bobtail Member
    23
    Nov 9, 2017
    For the last couple of weeks my '98 W900 has taken a bit to start. I have to crank it about 20 seconds before it kicks over. Once running it is great. It has a Detroit 60 in her.
  3. HopeOverMope
    HopeOverMope Road Train Member
    1,801
    3,211
    Feb 25, 2016
    I-20 LOUISIANA
    Sounds fuel related... possibly a starter, but more like fuel is draining back to the tank and is not readily available at prime for starting... I’m not to familiar with the Detroit 60 motor
  4. Espressolane
    18,686
    117,098
    A few things to consider
    Batteries could be getting weak.
    Fuel check valves.
    Lift pump weak or not working.
    Clogged filters.
    TripleSix, magoo68 and swaan Thank this.
  5. Gumper
    Gumper Road Train Member
    1,579
    3,847
    Jan 7, 2018
    Butte, MT
    Does the starter spin the engine as fast as normal when trying to start?
  6. lantern756
    23
    Nov 9, 2017
    Yes, starter sounds strong and batteries are pretty new. It use to start like a car. Just crank it ounce and it started; until it started this.
  7. TripleSix
    133,350
    If the batteries and starter are strong, check valves would be next.
  8. Bigrigmayo93
    Bigrigmayo93 Light Load Member
    132
    76
    Nov 28, 2016
    Chicago Illinois
    My truck would start normal if I drove it every day. But after two days of sitting, the truck wouldn’t start. It was the check valve.
  9. Lyle H
    Lyle H Road Train Member
    1,292
    2,942
    Apr 16, 2014
    Here is a simple thing to try before you start replacing things that don't need replaced.
    One by one, pull out, clean and replace the fuses in the fuse box. If one of them is corroded, it is possibly not supplying enough voltage to the fuel shut off switch.
    I know it sounds weird, but I know of at least two cases of friends of mine with older Detroit powered trucks that this has worked.
  10. Espressolane
    18,686
    117,098
    Truth in the electrical connection theory.
    Old fuses, corroded contacts or wires.
    Have had problems because of that.
  11. Gumper
    1,579
    3,847
    Jan 7, 2018
    Butte, MT
    My Cat didn’t like to start. Replaced the filters and things are fine. Filters are an easy place to start.
    There was a bird feather in my fuel filter. No idea how.
