Sludge in the blowby
Discussion in 'Ask An Owner Operator' started by DT Trucker, May 9, 2025.
  1. DT Trucker
    DT Trucker Bobtail Member
    4
    Feb 5, 2022
    I noticed this sludge in the oil tube and blowby tube, should i be worried?
    Cat c12
    670k after overhaul
    Little blowby
    No smoke whatsoever
    Thanks in advance
  3. Spyro2112
    Spyro2112 Medium Load Member
    643
    447
    Mar 17, 2018
    Water in oil. Smell it
    Rideandrepair and DT Trucker Thank this.
  4. Jordonh
    Jordonh Light Load Member
    52
    38
    Jul 1, 2022
    North Carolina
    When my E model starting having that, I was getting coolant mixing with my oil had the same sludge as showed in the picture but it was a little more thick then yours though. Pull a valve cover and make sure there is no sludge there.
  5. DT Trucker
    4
    Feb 5, 2022
    Definitely coolant in oil, coolant level was very low. Was it a cracked head in your truck or smth else?
    Rideandrepair Thanks this.
  6. wore out
    wore out Numbered Classic
    17,646
    221,054
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    Could be anything right down to a bad water pump. Pull the oil pan and pressurize coolant system, that’s the only way to know for sure where it’s coming from.
    Or you can poke and hope firing the parts cannon
    Banker, Oxbow, Rideandrepair and 5 others Thank this.
  7. Magoo1968
    Magoo1968 Road Train Member
    2,087
    5,562
    Mar 18, 2021
    St Malo mb
    Do you use any oil additives? In a c12 I ran 5 years ago I added some Lucas and had more blowby and some sludge . Next oil change didn’t add any and it went back to normal.
    Oxbow and Rideandrepair Thank this.
  8. Jordonh
    52
    38
    Jul 1, 2022
    North Carolina
    It was a leaking liner for me all of them had some very bad cavitation head wasn’t cracked which I was surprised so I rebuilt it for another use only.
    Oxbow, DT Trucker and Magoo1968 Thank this.
  9. 77fib77
    77fib77 Road Train Member
    11,863
    78,825
    Jul 7, 2010
    St Louis
    Air compressor?
    DT Trucker Thanks this.
  10. DT Trucker
    4
    Feb 5, 2022
    Yes i usually put 16 fl oz of Energy Release anti friction metal conditioner but i've been using that for years.
