Smart wheel issues
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Gumper, Apr 30, 2018.
  1. Gumper
    Gumper Road Train Member
    1,579
    3,847
    Jan 7, 2018
    Butte, MT
    My 97 W900 has sporadic problems with the Smart Wheel controls. The cruise and engine brake buttons don’t always function. It seems to get worse if the wheel is turned. Sometimes they won’t work at all even with the wheel straight. How can I access the connection from the wheel to the column? There must be some sort of disc that connects the wires from the column to the wheel. Am I SOL, and need to replace the whole setup?
    Honestly I hate the buttons on the wheel, and wish they were on the dash.
  3. Hulld
    Hulld Road Train Member
    2,884
    6,569
    Oct 19, 2015
    Upstate NY
    I am not sure on your particular truck but I would assume it would be the same set up as used in an automotive application.
    In a car there is a mechanism called a clock spring switch.
    It allows you to turn the steering wheel but still maintain electrically contact with you cruise control switches, air bag connections ect.
    In an automotive application this clock spring switch is able to be removed and serviced with a new one so I would think you would be able to do the same with your truck.
    As far as I know it would be a dealer item only so it’s best to start by contacting your dealers parts counter.
    Tug Toy and Gumper Thank this.
  4. ChaoSS
    ChaoSS Road Train Member
    3,338
    6,759
    Sep 20, 2014
    Probably a bit easier than on a 4 wheeler though, as you don't have the air bag to contend with.
    Tug Toy Thanks this.
  5. Hulld
    2,884
    6,569
    Oct 19, 2015
    Upstate NY
    Maybe slightly.
    Automotive airbags bolt in with a couple of bolts on the backside of the steering wheel and then they unplug and come out as a unit.
    No big deal really.
    Tug Toy and ChaoSS Thank this.
