SMART WHEEL KENWORTH T800
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Perchie15, Feb 9, 2024.
  1. Perchie15
    Perchie15 Light Load Member
    253
    75
    Aug 16, 2021
    Not sure what to think of this #### smart wheel. I the cruise doesn’t work nor does the break but the intermittent lights work. But ofcourse they go off soon as u stop pressing thr button so that’s normal for them but the Jake’s and cruise light shows on thr dash their on soon as u let go theirs nothing, I have 7V coming into the steering. Any help?
  3. RGN
    RGN Road Train Member
    1,617
    17,141
    Jun 13, 2014
    Never tried this with a .pdf see if it works
  4. RGN
    1,617
    17,141
    Jun 13, 2014
    If you can get the PDF to work its Kenworth SmartWheel troubleshooting guide, '01 and earlier I believe.
  5. Perchie15
    253
    75
    Aug 16, 2021
    Oh wow thanks! This is better then the wiring schematic I got
  6. Perchie15
    253
    75
    Aug 16, 2021
    N
    Now If these issues suddenly appeared after deleting codes would it have anything to do with a fail safe?
  7. Wildcase
    Wildcase Bobtail Member
    9
    Nov 3, 2022
    I had an issue with the Jakes not working with a smart wheel but the indicator light would come on. I didn't have regular toggle switches for them so i just pulled the toggle switch panel on the dash and the harness had the plugs labeled for jakes,cruise etc. Got the toggle switches, plugged them in and they worked perfect. Could be an option for you if you don't figure out your problem.
  8. Perchie15
    253
    75
    Aug 16, 2021
    I’ve been thinking that forsure! Might have to just to get it to work but might be going to KW also! To get this beast fixed. When u likely deleted the smart wheel since theirs more then 3 Jake options and cruise control settings how could u move it to a toggle switch?
  9. Wildcase
    9
    Nov 3, 2022
    i just got some factory Jake switches and put them in the factory spare switch locations i had on the dash. I only did the 2 for the Jakes but the wires were there for the 2 cruise switches as well.
