Smoke in cab - burning eyes
Discussion in 'Ask An Owner Operator' started by Okie Trucker Girl, Jan 3, 2022.
  1. Okie Trucker Girl
    Okie Trucker Girl Bobtail Member
    30
    63
    Jan 3, 2022
    Update 2**
    Please check picture on page 3…. I think it’s way worse than the heater
    Update**
    ****Lifted the hood and didn’t see anything that had obvious signs of melting/burning. Checked the batteries and they’re dirty but not wet or overheating. I saw the white smoke again coming from behind where the dash is in the engine compartment. I turned truck off immediately so not much more I know other than it’s gotta be something in the dash right? ****
    2012 Volvo with bad batteries and sitting in -2• weather. Have to start my truck every few hours to keep the batteries from giving out and this last time after about 10 mins I pulled back the curtain (I was laying in the bunk) and there was smoke and a burning sensation in my eyes. I think it’s coming from the heater but I’m new to this and don’t know where to even start looking. Gonna wait until daylight to get under the hood, but would appreciate some ideas on where to start. As for the batteries, they’re on the list of things to replace/repair when I head home in a few days.
  3. AModelCat
    164,925
    Sounds like an exhaust leak.
    If its burning your eyes it is slowly poisoning you. You don't want to be running the truck, people have died because of exhaust fumes.
    Chances are fixing the leak won't be a job that can be done easily in a parking lot. If you're looking for an exhaust leak, inspect all the manifolds and pipes for black soot, that'll be the location of the leak.
    77fib77 Thanks this.
  4. feldsforever
    feldsforever Road Train Member
    1,453
    1,440
    Nov 22, 2019
    I had smoke coming in from the passenger side heat vent during regens. The one box was getting so hot it melted the plastic fairing piece. And would be so much black smoke. I thought I was on fire.
  5. 201
    201 Road Train Member
    12,805
    26,354
    Apr 16, 2014
    high plains colorado
    If it's that cold, why are you even shutting it off? I'm sure you would know if it's an exhaust leak, it's probably the fan step down switch, like for on low, is probably melting. When that ultimately frys altogether, you'll have high fan, but no med or low.
  6. Okie Trucker Girl
    30
    63
    Jan 3, 2022
    I’m not turning the heater on when I’m running the truck, it’s in the off position. I have a bunk heater so I don’t need to idle the truck. I’ll look up some information on that switch and see if that’s it, thank you
    77fib77 and 201 Thank this.
  7. Okie Trucker Girl
    30
    63
    Jan 3, 2022
    Not sure which vent it’s coming through, I’ll have to turn it on to watch it and then go from there.
    feldsforever Thanks this.
  8. Okie Trucker Girl
    30
    63
    Jan 3, 2022
    I don’t believe it’s an exhaust leak (which was my first thought). I’ll make sure to check for the black soot though just in case.
  9. feldsforever
    1,453
    1,440
    Nov 22, 2019
    At minimum I would roll down the front windows and get fresh air In there Espeacialy iif your getting dizzy. Thats a sign of low oxygen.
    Do you have a detector in your truck.
  10. 062
    062 Road Train Member
    6,338
    33,982
    Oct 20, 2013
    Does it smell like rotten eggs? If so your batteries are getting hot and gassing off.
    mtoo and feldsforever Thank this.
  11. feldsforever
    1,453
    1,440
    Nov 22, 2019
    Mine do that sometimes. Whats the cure for this?
