Smoker ignites blaze at gas station after lighting cigarette near fuel truck
Discussion in 'Trucking Accidents' started by Chinatown, Nov 11, 2025.
  1. Chinatown
    Chinatown Road Train Member
    79,364
    193,019
    Aug 28, 2011
    Henderson, NV & Orient
  3. Chinatown
    79,364
    193,019
    Aug 28, 2011
    Looks like the flame started at the table from fumes drifting from the fuel hose.
  4. Arctic_fox
    4,808
    27,518
    Sep 16, 2016
    Aaaaaaand this is why no smokeing within X amount of distance signs are a thing and also why they are there for a reason.
  5. RockinChair
    RockinChair Road Train Member
    5,582
    15,780
    Feb 19, 2012
    Corpus Christi, TX
    That is because the fuel hauler only had one hose hooked up, which means that he was not recovering vapors back into his tanker. Either he was venting the vapors directly out of the tank or they were coming out of the vent stacks and settling down around the customers.
    Also... I can't believe they put the drops so close to the seating area.
  6. mjd4277
    mjd4277 Road Train Member
    15,145
    47,674
    Oct 4, 2015
    Fitchburg,MA
    If this isn’t a sign to quit smoking I don’t know what is!!
  7. 201
    201 Road Train Member
    13,042
    26,942
    Apr 16, 2014
    high plains colorado
    :laughing-guffaw:Nice going, yutz. I thought the driver was the one that lit the cig, IDK, you can't really blame the doofus, but couldn't they smell anything? Just shows to go ya', people light up cigarettes so routinely, they don't look around. Could have been MUCH worse, and if I was that driver, that guy who lit the cig would be shopping for dentures.
    I read, a lit cigarette is not hot enough to ignite gas fumes, it takes a spark or a flame. As mentioned, we have vapor recovery that almost eliminated any risk, but I still see low brow cashiers sneaking out for a puff.:hello2:
    broke down plumber and The_vett Thank this.
  8. Long FLD
    Long FLD Road Train Member
    13,450
    57,154
    Mar 4, 2015
    For the vapors to be on the ground like that I’m guessing the driver was the one venting them. If they had vent pipes I don’t think the vapors would settle like that.
    It’s also a foreign country so who knows that the entire situation was. But here in the Midwest we still have a ton of places with vent pipes and I’ve never been concerned about vapors settling. If there’s not vent pipes a lot of people still don’t hook up a vapor hose when it’s good and windy.
  9. The_vett
    The_vett Medium Load Member
    617
    3,432
    Jan 8, 2021
    So Cal / PNW mostly
    Off the Truck subject, but GM sent me a letter telling me my car is one of the bunch that has a manufactuering defect that can cause it to start a fire or even explode.
    They have recalled it and said I have to wait for the fix because they don't have the part to fix it. They then told me they would send another letter when the parts are available and they can then fix the problem. This was a couple months back, and I have heard nothing from them.
    The deal is having my car expolde and kill me, is just the worst problem. This car has so many things that are not right. They also are not confined to the fuel system. There are electrical problems, transmission problems, and many more,I can't trust the car, and thats unacceptable. sorry for the rant.
    But yes , we all need to be careful at the fuel pumps!
  10. Arctic_fox
    4,808
    27,518
    Sep 16, 2016
    Only partially true. The U.S require big tobacco to use chemical laced self extinguishing paper. They burn a lot colder then elsewhere. Ive had overseas cigs before i stopped smoking them and they are a totally diffrent animal. And even then they are pretty inconsistant so you can have one that has almost no coating.
    That said its still on fire and can cause an explosion especially when you puff if the fuel air mix is right.
    Feedman, The_vett, 201 and 1 other person Thank this.
  11. broke down plumber
    4,849
    39,581
    Jan 25, 2024
    Years ago i can remember cell phones causing blazes at the pump , at least thats what was reported .
    Flat Earth Trucker, The_vett and 201 Thank this.
