Smoking after inframe
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Canary379, Aug 1, 2014.
  1. Canary379
    Canary379 Light Load Member
    73
    Apr 13, 2012
    Illinois
    Just looking for some answers from my forum friends... I have a cat c12 that has about 50,000 miles on it since it's inframe was done. Before the inframe I barely had any smile at all coming out of the exhaust. Ever since I drove out of the shop and to now it is always blowing a good puff of black smoke upon acceleration and also if I am climbing a grade under load it will smoke in the lower rpm range.
    Anybody have any any answeres as to what may be happening or going on? Also I found that I have traces of oil droplets at the bottom of the breather tube at the end of the day.
    Thanks
    nick
  3. rollin coal
    rollin coal Road Train Member
    13,645
    28,053
    Mar 29, 2008
    TN
    Might be a boost leak. I'd check all the boots and tighten the clamps. Did you replace or at least check the CAC for leaks when it was inframed? They all have traces of oil inside the blowby tube that's normal.
    wore out Thanks this.
  4. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    Replace air cleaner then mark MI. on tape on outside and keep track of MI. on each filter 50 or 60,000 mi is agood start with 1 air cleaner.
  5. Canary379
    73
    Apr 13, 2012
    Illinois
    I will check for a boost leak thank you. I wish I had a gauge in the cab!
  6. rollin coal
    13,645
    28,053
    Mar 29, 2008
    TN
    What he said about dirty filter too.
  7. Powder Joints
    7,996
    8,427
    Sep 25, 2007
    Rosamond, SoCal
    sounds like they changed your injectors to larger ones
  8. wore out
    wore out Numbered Classic
    17,396
    216,177
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    A gauge in the cab is nice but if there is a small leak it will still make all the boost in the world but smoke a little and loose horsepower. I know it doesn't make sense most of the time you won't notice the power loss till its fixed.
  9. Canary379
    73
    Apr 13, 2012
    Illinois
    I am guessing that the consensus is that there might be a boost leak. Will need to find time and get it looked at.
  10. Pool6710
    Pool6710 Medium Load Member
    662
    258
    Aug 10, 2014
    Minnesnowta
    I have a c12. It don't spool below 1200 rpm's and smokes till it spools.
  11. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    had shop put a 6 pack inj in 1 time & set the fuel, where I got better m.p.g. better. h.p. but smoked a lot. 1 inj lasted just til warranty was over. had my local shop replace the one. & reset inj, no more smoke, not another prob with inj, but loss the power increase. inj & fuel setting will cause what you are describing, but the other things posted by others will too. good luck.
