Snow and bridges?
Discussion in 'Questions From New Drivers' started by Canadianhauler21, Nov 29, 2018.
  1. Canadianhauler21
    Canadianhauler21 Heavy Load Member
    865
    1,643
    May 15, 2017
    First winter driving a truck, drove many in my personal car. Never payed much attention to snow on bridges until recently, usually see those "bridge ices before road" signs. Noticed they always seem to have quite a bit of snow on them when the rest of the road seems clear.
    Any certain precautions to take on these bridges?
  3. KillingTime
    KillingTime Road Train Member
    3,865
    61,879
    Mar 26, 2016
    Rockland, Maine
    Drive real fast (to get off it quicker) and make sure you try to change lanes as many times as possible. And if you have to brake do it really hard - stand on it: both feet, while, at the same time, turning your steering wheel.
    Helpful?
  4. DieselDrivinDaddy
    DieselDrivinDaddy Light Load Member
    230
    531
    Feb 13, 2016
    Poconos, PA
    I also try to take an extra drink of whiskey before I cross the bridge. You know, for good luck.
    Rugerfan, tscottme, buddyd157 and 5 others Thank this.
  5. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,144
    Mar 5, 2016
    White County, Arkansas
    I buy a case or gallon of good drinking and make carousing the night before the storm, get it all out of the system. Then commit the soul to God because my ### belongs to that icy bridge and more to come. //half teasing.
    You do not want anyone next to you on a bridge. Especially those that curve. AND those ESPECIALLY that lean to one side to slope towards the railing to the right or left. You do NOT want anyone getting between YOU, ESPECIALLY that #### trailer of yours and that railing. Use your body weight, throw it around and take over that lower side of that bridge.
    Then walk her across. Literally idle in 1st. Ready to point tractor upslope when your trailer jackknifes to the lower railing.
    Here in the south, in Mississippi, they might sand a bridge a foot thick. Get up there and get it moving. Straight. Do not stop for nothing Get across at torque with room to add more beef to the pulling rather than high RPM that will spin your drives.
    Some bridges are giants. If they tell you they are closed. They mean closed. You do NOT want on it. I don't care if you are the Almighty.
    Others as found on the interstate well... there are some that are pretty good for ice. As it will cake over and freeze to the point of not letting anyone over. Hopefully you got across before the temps got too much below 34. (Winds compress under bridge chilling the #### thing FAST to ice. You might be tooling along fat and happy at 34 degrees on pavement, hit the bridge and around you go. Maybe even go over.
    One bridge at a time. IF you see a bridge chocked with accidents, piled cars and trucks etc, Don't get on there and add to the problem. Wait a while.
    Get weather forecasting before you move that truck a inch for the workday. Your route you thought would be good at breakfast will be hell to pay by lunch.
    Canadianhauler21 Thanks this.
  6. Lepton1
    Lepton1 Road Train Member
    12,647
    25,589
    Nov 23, 2012
    Yukon, OK
    Coasting. Is. Your. Friend.
    Remember that mantra ANY time you get squirrelly.
    Ease off on the throttle. Don't get all the way off the throttle. EASE off the throttle.
    Bridges DO ice up earlier than the rest of the road, but no need to get all truck stop story over it. Just carry on.
    Hatt91, IluvCATS, JonJon78 and 9 others Thank this.
  7. J Man
    J Man Medium Load Member
    306
    197
    Dec 31, 2011
    Middle of nowhere
    What Lepton1 said. Also, watch for those changes in pavement type before and after the bridge. Kind of a bump in the road where the surfaces are joined. Don't be getting onto the throttle when you bounce across those. As long as you are aware that you need to be more careful about bridges and you ease up slightly on the throttle as you make your way along you should be fine.
  8. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    No cruise control.
    Went through Thunder Bay one morning just around the freezing point. Every bridge had at least one car spun off into the ditch just after it.
    x1Heavy, Canadianhauler21 and Lepton1 Thank this.
  9. Brandt
    Brandt Road Train Member
    4,626
    6,361
    Sep 17, 2012
    Float the bridges. If your going downhill brake before the bridge to slow down then take foot off the brakes and float across the bridge. Basically don't make any sudden changes to brakes or power on snow or ice bridge.
    If your going uphill turn on the power divider before your tires are spinning, if going downhill turn it off. Add a little power and pull the trailer across the bridge. Don't let it push you across the bridge.
    Always pull the trailer because it will always want to go straight.
  10. CrappieJunkie
    CrappieJunkie Wishin' I was fishin'
    3,996
    19,137
    Mar 9, 2014
    In a van down by the River.
    Slow down.
  11. 201
    201 Road Train Member
    12,791
    26,323
    Apr 16, 2014
    high plains colorado
    Turn the engine brake off,,:eek:
