Last week my B/W turbo (same as PDI Stage 1) came from the UPS guy and ...#####... that thing is big!!!
How do you measure size/performance/flow from one turbo to the next? Cfm, # of vanes or length? All the guys at P/Power told me was that "it's bigger"... and that was lame.
I'm wondering how this one compares to a stock 6NZ turbo.
So how dow you compare turbos?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by paul 1052, Nov 10, 2010.
They should be able to give you the flow rate numbers along with the intake and compressor sizes. If they cannot, just walk away and find someone who has an idea about what they are doing.
Remember, you can run into issues changing out, for example, a 300cfm # 20psi turbo setup with a 750cfm # 20 psi. By pushing more cfm you are leaning out the mixture and must compensate with higher fuel pressure, larger injectors, and/or EEC programming.
If the person cannot give the flow numbers and impeller/compressor sizing, like I said earlier, walk away. -
Bigger may not always be better. As said above if it is pushing a lot more air you may have some problems.
Most turbo shops will give you the air flow measurements in Lbs per minute of airflow. Some will even you give you cubic feet per minute CFM. A turbo that will move 140 Lbs per minute will move 2000 CFM. Your engine should require 115-120 Lbs per minute.
What everybody calls a BW Stage 1 turbo for a CAT engine could be different. Everybody has a different interpetation of how to build a turbo for this engine and horsepower range.
The turbo you have shouldn't be much larger physically than the one you have now. -
Are you certain about that. I've seen and talked to a diesel mechanic. You can burn out any engine by running too lean. If you understood what I wrote I was getting the point across that more CFM at a certain boost level is a lot more air into the engine. Also that any shop should give you all of the numbers, if they cannot then find another shop.Diesels are always running lean, so no danger to break something. Without extra fuel it's just hard to spin a bigger turbo.Click to expand...
Yes, you can burn diesel engine only running too rich what means smoke and high EGTs. Gasoline is vice versa.Flying Finn said: ↑Are you certain about that. I've seen and talked to a diesel mechanic. You can burn out any engine by running too lean. If you understood what I wrote I was getting the point across that more CFM at a certain boost level is a lot more air into the engine. Also that any shop should give you all of the numbers, if they cannot then find another shop.Click to expand...
More CFM at same boost level is only possible if you do some changes to engine breathing ability, like porting, or turbocharger that has better boost/backpressure ratio, not all of these "upgrade" turbos have.
It's difficult to get airflow numbers and maps for turbochargers because manufacturers for some reason don't want to publish them. Garrett is easiest, some BW models quite easy, Holset most difficult. In Finland there's a turbo shop that can get all the information of modern Holsets, but none of the older like HT4.
Wheel sizes and housing numbers should be easy, if the shop can't give them, you are right, find another shop. -
V8Lenny is on the right track. It's really hard to get a diesel to run in a lean condition. A diesel running lean is starved for fuel. Just like a plugged fuel filter, runs rough and no power.
Adding CFM without increasing boost pressure means that you will only flow as much air as the smallest choke point allows. Most upgrade turbo's also push more pressure, that gets you more air into the cylinder. The intake tube on a cummins ISX would be replaced on any truck I owned.
Related Categories
Isuzu Elf 4JJ1 - DPD forced...
aito_jptruck posted Jul 18, 2026 at 9:30 AM -
ultrashift plus dash display...
jpx2 posted Jul 17, 2026 at 10:06 PM -
96 FLD120 AC issues
irishluck09 posted Jul 17, 2026 at 10:00 PM -
How much paint for a T600 with...
RustyBolt posted Jul 17, 2026 at 7:25 AM -
2007 T600 turn signal issue
RustyBolt posted Jul 14, 2026 at 6:04 PM -
How to de-pin the 9 pin J1939...
Deezl Smoke posted Jul 12, 2026 -
2017 F550 Very Loud...
itsbroken posted Jul 11, 2026 -
Mystery part in 3406B oil pan
Almach posted Jul 11, 2026 -
1989 F800 with Allison...
kmmontandon posted Jul 11, 2026 -
1998 Ford Aeromax 113 wiring...
Raffito posted Jul 10, 2026
Loading...
Recent Threads
Two tractor trailers collide in...
RhodeGuy762 posted Jul 18, 2026 at 11:40 PM -
5 Decisions That End Trucking...
lual posted Jul 18, 2026 at 10:47 PM -
Newbie in Augusta, GA – Looking...
Ken82 posted Jul 18, 2026 at 6:33 PM -
The “Death of the Stickshift”...
Tarh331_Dad posted Jul 18, 2026 at 3:44 PM -
Has anyone here reported their...
10538 posted Jul 18, 2026 at 6:02 AM -
96 FLD120 AC issues
Flatbedders can’t back up
crzyjarmans posted Jul 17, 2026 at 9:44 AM -
Loading...
