So, I have a leak.
Discussion in 'Freightliner Forum' started by truckthatpassesyouby, Jun 29, 2016.
  1. truckthatpassesyouby
    truckthatpassesyouby Road Train Member
    1,876
    6,128
    Jun 3, 2015
    It's coming from the metalic nozle(overflow) that connects a small hose to the coolant reservoir on the upper part of the engine. The leak is squirting sprays of coolant out all around the right side of the engine. My coolant level is fine, but all that coolant on the wires is worrying.
    Can I drive it to a shop or will the coolant cause a spark and cause a fire somewhere down the road - or even on ignition?
  3. Getsinyourblood
    Getsinyourblood Road Train Member
    1,274
    1,811
    Jul 5, 2014
    Retired. North Texas
    truckthatpassesyouby Thanks this.
  4. RustyBolt
    RustyBolt Road Train Member
    2,073
    3,335
    Feb 21, 2015
    Bement, IL
    Before my in-frame, mine was blowing a gallon a day all over the engine. This went on for weeks until I had the cash. Don't worry about it. Have it fixed when you can.
  5. Dave_in_AZ
    424,676
    Shouldn't there be a small rubber hose attached to said nozzle so it goes on the ground rather the engine?
  6. bavarian
    bavarian Heavy Load Member
    730
    785
    Feb 13, 2014
    Winnipeg
    What's the definition of "until I get to a shop"?
    Two miles?
    Today after your delivery?
    When home in 2000 miles?
    Have it fixed ASAP. If that nozzle brakes away, you're loosing coolant instantly. Then guess how far you make it. One hour of a tow truck bill will fix a lot if avoided.
  7. rolls canardly
    rolls canardly Road Train Member
    1,639
    4,138
    Feb 7, 2009
    mt. pocono. pa.
    Somewhere in your travels stop in an auto parts store or repair facility that has some kind of tubing that will fit over the hose barb. Yes, there should be a hose on it. and yes it should be routed out of the way so it just pisses harmlessly on the ground. Don't think it would catch fire, but you could short out something
    if the liquid happens to find two cracked insulation places on your wires. Cheap fix, couple bucks.
    I would worry why I had pressure in the bottle.
    Rolls Canardly.
  8. bavarian
    730
    785
    Feb 13, 2014
    Winnipeg
    It's the nozzle that's leaking, not the hose. Pressure in coolant system is usual up to a certain point. That's making it spray.
  9. MrEd
    MrEd Road Train Member
    2,196
    2,836
    Sep 2, 2011
    Winfred, SD
    If it's the overflow hose that points to the ground, just get it fixed pretty soon so it isn't making a mess all over under your hood. If it is a hose that goes from the radiator to the motor, and is supposed to be a closed loop, get it fixed A.S.A.P. If it gets worse, you will be into an expensive problem in just a few miles or so. I agree with Bavarian. Towing gets spendy fast. Often faster than simple repairs get spendy.
  10. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,769
    Mar 5, 2012
    Ontario Canada
    Replacing a hose is something I would consider even ta petro mechanics capable of doing. Alternatively there is this black stretchy tape you can buy that binds onto itself. I've used it before works well. Not for long periods though just to get you to a shop. If you are going to just let it leak slowly consider using water instead of coolant as you are just spraying it onto the ground. System usually holds 12 gallons. Depends how fast you are losing it I guess ..
  11. rolls canardly
    1,639
    4,138
    Feb 7, 2009
    mt. pocono. pa.
    And if its the hose barb/nozzle, whatever you want to call it, that is leaking,
    You can try cleaning with acetone and try to epoxy it, but most voodoo mechanics don't work.
    You need a new one. See if you're lucky and it is threaded in. Does it come out from the Block? Radiator?
    If it is a threaded fitting - its a simple "replace the fitting" w/Teflon tape on the threads.
    I've had fittings spray like that after they were bumped accidentally and bent - to form a small crack.
    Sorry, Sounded to me like "truckthatpassesyouby" meant the reservoir overflow hose was missing?
    Rolls Canardly
    I can read readin' - its the readin' wrightin' part that gets me. I'm Old.
    Run down.
    Tired.
    Wore out,
