Solid ABS light on trailer, entire abs system down on trl
Discussion in 'Trucking Industry Regulations' started by CassAnn, Sep 6, 2014.
  1. Guntoter
    Guntoter Road Train Member
    1,659
    1,521
    Mar 24, 2012
    Phoenix, AZ
    Fuel haulers disconnect them on every trailer. They are on when the key is off and you can't have a light on while loading, so... Disconnect it...
  3. peterd
    peterd Medium Load Member
    349
    365
    Jan 7, 2012
    St.Catharines ON
    You are incorrect.ABS light would only come on when ignition turned on to check system.When light stays on during malfunction it still must have ignition switch on.ABS is powered through blue wire in trailer cord and if wired properly only has power when ignition is on.
    Raiderfanatic Thanks this.
