Solid white Regen light on 2022 Peterbilt 579
Discussion in 'Questions From New Drivers' started by nextgentrucker, Jun 2, 2025.
  1. nextgentrucker
    nextgentrucker Road Train Member
    1,719
    1,635
    Sep 25, 2023
    Port Saint Lucie, Fl
    As the tiltle said, what does this light mean?
  3. tscottme
    tscottme Road Train Member
  4. Rugerfan
    Rugerfan Road Train Member
    7,976
    41,709
    May 3, 2011
    Redding,CA
    Pull down your sun visor. It’ll tell you usually up there.
    wulfman75, tscottme and ducnut Thank this.
  5. Long FLD
    Long FLD Road Train Member
    13,416
    56,936
    Mar 4, 2015
    You need to do a parked regen. If you keep driving it will start to flash, and later it will flash and the check engine light will come on.
    nextgentrucker and tscottme Thank this.
  6. Moosetek13
    Moosetek13 Road Train Member
    15,176
    19,416
    Nov 1, 2010
    Burnsville, MN
    Oftentimes, when a light would show up that I didn't understand, I would read the owners manual for the engine.
    Suspect Zero, tscottme, Numb and 4 others Thank this.
  7. nextgentrucker
    1,719
    1,635
    Sep 25, 2023
    How do I do that? I tried to do it yesterday but it wasn't working.
  8. nextgentrucker
    1,719
    1,635
    Sep 25, 2023
    It was at the shop, it had a check engine light and did say it needed a regen, they changed some sensor and stuff, I thought they regen it, I guess not.
  9. ESAFO
    ESAFO Light Load Member
    172
    443
    Jan 2, 2022
    Hubbard, Oh
    Your truck will tell you when\if it needs a 'Park Regen' anytime you set your brakes.
    Most times your truck will do a rolling regen while moving you can tell when that is taking place, you will have a slight loss of power & you might hear a tone difference kinda like a compressor running.
    When that light comes on usually after driving for awhile & you stop, most times indicates it's finishing its burn process & the light will go out when finished.
    If this continues to be a frequent issue light coming on, than there probably is another sensor bad or also might need the DPF filter removed & properly cooked in a oven.
    nextgentrucker Thanks this.
  10. Long FLD
    13,416
    56,936
    Mar 4, 2015
    That’s not accurate. That’s not the high exhaust temp light. The light in the pic means it’s asking for a parked regen because the soot level in the DPF is getting too high.
    Concorde, tscottme and nextgentrucker Thank this.
  11. Long FLD
    13,416
    56,936
    Mar 4, 2015
    Set the brakes and hold the switch down for a few seconds.
    Concorde and nextgentrucker Thank this.
