Some Help For An In-Experienced...
Discussion in 'Trucks [ Eighteen Wheelers ]' started by SmK PANDEMIC, Jul 18, 2016.
  1. SmK PANDEMIC
    SmK PANDEMIC Bobtail Member
    4
    I'm looking for some help in considering which truck to buy. I am a recent layed-off oilfield worker. I'm 26 and have been working in the oilfield since I was 18. The past 6 years I worked for the same company. I started from the bottom and worked my way up to an Operations Manager. I worked on the drilling side of things so everything is 24/7 on call work, handled all of the sales, dispatching, hiring, safety, equipment repair and maintaining, and regularly covered jobs when things were busy. Yes, all that, by myself. I moved to San Angelo, TX, to open a new yard for my company. I was supposed to have an assistant manager come with me, but he never made it. Time went on and as the owners of the company started to see I was capable of doing it on my own, reinforcements never arrived. Those 6 years were tough and trying as I had no management experience what so ever. However, I'm grateful to have had those 6 years as I believe I learned a great deal of many different aspects of running a business.
    With that being said, I am somewhat knowledgeable on running a business, picking up work, maintaining work, and doing what it takes to overcome competitors. I've tried looking for work, but its extremely difficult not only because of the oilfield still being horrible, but because It's hard to realize that I'm going to have to start completely over somewhere else. I'm not one to be picky, either. I've thought about my options over and over and I don't think it seems fair to myself to have to do that. I'm going to have to do it anyway, though.
    So, I've decided that if I'm going to have to do it, I might as well do it for myself, not someone else. I may be a fool for trying to do something I have little to no experience in, but I'm going to give it all I've got.
    I would like to purchase a tractor and belly dump. I have a few contacts and I believe I can keep it working steady. My concerns are spec'ing a truck, the perfect truck for the job, as well as bottom dump trailer.
    Luckily, my credit is still great and I, well my wife is very good with money. We would be okay without work for a good amount of time, I'm just not one to sit back and watch everyone else better themselves while I sit and do nothing.
    So, some information on what I think I'll be doing -
    Hauling sand, gravel, soil
    Probably within a radius of 200 Miles
    I have a contact who owns a large hauling operation and his own materials. So, I believe I can pick up work a bit easier knowing where to get the materials and at a discount I might even be able to make some money off of it too.
    And to the point, I believe my budget for a truck and trailer combined is going to be about $30,000. $15,000 to $20,000 for a truck and $10,000 to $15,000 for a bottom dump trailer. I contemplated starting of with a straight dump truck, but I feel I would be limited in the amount and availability of work to bring in would be. I'm not looking for anything fancy or new and definitely do not want anything to do with DEF. I know very little about the trucking industry and I'm trying to learn as much as I can. I just need a truck that will be reliable and perfectly suitable for hauling a belly dump up to 88,000 lbs. Can you guys give me some insight on what size of engine, hp, torque, transmission and anything else that could help me? I know for sure I want a day cab. I can look this stuff up all day, I just don't want to end up with what I thought was a good truck for a good price and it end up being the one year model that no one would touch with a 10 foot pole.
    As far as the trailer, I just need it to be functional and ready to take a beating. Any help or suggestions will be greatly appreciated. Thanks everyone.
  3. tnevin225
    tnevin225 Road Train Member
    1,166
    1,601
    Jan 1, 2014
    Might look at something like a T800 KW 98-02, with a cat C-12 or C15, 13 speed and 370 rears. Some place to start anyway. Remember pre 03 will keep you away form all the Emition problems.
    SmK PANDEMIC and rachi Thank this.
  4. SmK PANDEMIC
    4
    I came across this 1998 Peterbilt 378 with a C-15 engine. It's a 10 speed though. I'm assuming walking beam tandem axle might mean the wheelbase is adjustable? Looking at regulations, in order to be up to 80,000 gross lbs, your wheelbase must be 51 ft. from front axle to rear trailer axle and 36 ft. from front drive axle to rear trailer axle. Is this correct?
    Also, I'm beginning to see that mileage on these trucks offers very little insight on its actual over condition. What are some other factors I should be looking at when determining overall condition of the truck?
  5. justa_driver
    justa_driver Road Train Member
    1,105
    817
    Apr 2, 2014
    Tennessee
    You might do a truckfax on it to make sure it hasn't been involved in any major accidents? Also check the frame out good on it for rust, breaks, or blisters in the paint on the frame. If you find any of that, it could mean its been in a lot of road salt, which will weaken the frame. The truckfax should tell you where its been most of its life.
    Id see if the seller has any maintenance records on it. It being a 98, its probably got around 1.5 to 1.8 million miles on it? Listen for odd engine noises and make sure the tranny shifts out smoothly(with no throwout bearing noise) and make sure the clutch brake works well (mash the clutch all the way to the floor and no grinding when you put it in gear). Id check it for any leaks, check the air lines and brakes, air leaks, make sure all the gauges work, excessive smoke and color, Check the bushings in the walking beams and suspension, etc.
    Sounds like a lot but any of that could tip you off to potential problems you may have to deal with once you buy it.
    Might be a good idea if you decide to buy it to replace the water hoses and drive belts? Running a diesel engine hot could be fatal? Id also do a service on it changing the fuel, oil and water filters and checking the air filters. Good luck.
    SmK PANDEMIC Thanks this.
  6. AModelCat
    165,226
    Most trucks we use for anything off road (logging, gravel, lowbed etc) around here are typically spec'd with 46k lb rears. Ratio is usually around 4.10. Neway air ride, 3/8" frame rails and 18 speed tranny. Ground clearance is another thing to consider. Job sites aren't all nice smooth. There could be times where you'll be diff deep in mud.
    If you're buying a truck that ran short local hauls I would be more concerned about hours rather than miles. Its not uncommon to come across a used truck with low miles and high hours in those applications.
  7. SmK PANDEMIC
    4
    I believe Ive decided on a 1998 Freightliner FLD120 Detroit 60 Series. 500,000 miles. What do you guys think?
  8. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,769
    Mar 5, 2012
    Ontario Canada
    500k miles on a 98? You sure there isn't a 1 or a 2 hiding in front of that 5?
  9. AModelCat
    165,226
    If mileage is that low I bet the engine is pushing 20k hours or more.
  10. Rick Wilmath
    Rick Wilmath Light Load Member
    57
    May 15, 2016
    Since you will be essentially local you could take greater risk with the tractor. I drove a belly dump
    for a guy last year and his equipment, including my truck, was ancient. He got paid the same as the guys with brand new trucks and I only had one breakdown and that was for a hose that should have been replaced during the winter.
    500k miles on a 98 doesn't sound right. I would be skeptical of any odometer on that old a vehicle, especially a semi truck. You can get 98's for less than $10,000.
  11. MACK E-6
    50,192
    240,063
    I have about 24000 hrs on mine, with roughly 650k miles.
    Still runs good though. I guess knowing how to drive helps.
