Sore joints starting out?
Discussion in 'Questions From New Drivers' started by Taffil, Aug 18, 2014.
  1. Taffil
    Taffil Bobtail Member
    Aug 18, 2014
    Heya TTR members! This is my first post at this place, and while I expected it would be about my first trucking company, I have an even bigger problem...
    I just finished CDL A school, and my joints hurt like Hell and a Half. It started the first week in the yard and road training with my elbow. After last week on road driving and taking the state test, my wrist is starting to bother me. My wrist hurts so bad I barely want to lace up my shoes. Is this typical for someone getting used to the repetitive motion of shifting? And before someone suggests I'm some white collar pansy, note that I'm capable of tough physical jobs, from moving ten yards of sand by myself with nothing but a shovel and wheelbarrel, to shoveling snow and salting sidewalks for 12 hours straight, to being a regular gym buff. I'm pretty physically tough, yet nothing has hurt my wrist and elbow joints as much as driving those ten speeds they had at the school.
    It has occurred to me that A) I have been forcing the shifter too hard, exerting too much torque on my arms and B) the shifters at the school are shot to tarnation being abused by the students, but I can't help but worry that shifting isn't going to jive with my body.
    Before I run straight into the arms of a carrier with mostly autos such as TransAm or Maverick, can anyone tell me this is fairly typical to experience as a student driver? Will it go away once I rest and learn to relax with the shifter? I really, really want to be a trucker and get paid to be OTR across the country, but I don't want it to cost me the functioning of my arm.
    Any advice or encouragement is appreciated. Thanks!
    -Taff
    Chinatown Thanks this.
  3. Chinatown
    Chinatown Road Train Member
    77,872
    185,050
    Aug 28, 2011
    Henderson, NV & Orient
    You probably are gripping the shifter too hard and resting your hand on the shifter when driving down the road with a firm grip on it. Don't rule out companies with auto transmissions; let the transmission do the shifting then you have one less thing to think about.
    West TN Trucker Thanks this.
  4. dog-c
    dog-c Road Train Member
    1,852
    1,546
    May 30, 2011
    New York, NY
    Get a back roller.....I use this every night after driving it helps...you can find them on amazon for 15-20 bucks....also drink lots of fluid and stretch....avoid soda and the pizza at loves...if you must eat pizza do it once a week....
  5. GWIZ2260
    GWIZ2260 Light Load Member
    90
    42
    Jul 3, 2014
    Lafayette, IN
    I agree that you may be exerting too much grip and force on the shifter. Speaking from prior experience in a factory, it was normal for people to be sore for a couple weeks until their bodies adjusted to the new "routine". Unfortunately, some people's bodies never adapt and actually have hurt themselves to the point of surgery. I guess the questions I would have is how long has this been going on? The duration as wasn't sure how long your schooling was. If you believe it may be due to the way you were handling the shifter, then maybe you can make a conscious effort to grip the shifter with less force, and/or also just let the shifter "fall" into gear. I am definitely no doctor, but don't want you to hurt yourself either. My best friend at my former employer actually had to quit as his body was falling apart from the repetitive nature of the job... hope this may help you. Good Luck!
  6. tucker
    tucker Road Train Member
    12,647
    40,425
    Jun 13, 2008
    IN
    Get a copper bracelet, it stops joint pain. Plus the pain is imaginary and is just your way of telling yourself that you are stressed out mentally, that's it. This is a giant step in your life, accept it and relax and enjoy the journey.
  7. notsonewb
    notsonewb Light Load Member
    180
    78
    Jul 29, 2014
    I never had this the thing from shifting a modern truck, but it might be as was said too tight a grip , may be from holding onto steering wheel to tightly also , could be simple dehydration , I know it sounds weird but its one of top signs is unexplained cramping ect , hope it gets better , I really expect that all trucks one day will be automatic , just my .02¢
  8. MsJamie
    MsJamie Road Train Member
    The continuous vibration from resting your hand/wrist on the shifter will cause inflammation. I had the same problem; just learn to not ride for extended periods with your hand on the shifter. Ibuprofen or naproxen will do wonders.
    Also, you should be able to shift gears using only two fingers on the shifter. Caress it like it's your girlfriend; don't grab it like it's your... manhood.
    GWIZ2260, wulfman75 and bergy Thank this.
  9. bergy
    bergy Road Train Member
    1,189
    1,311
    Nov 1, 2013
    Wait, what forum am I on...
    lol
    blairandgretchen and Lepton1 Thank this.
  10. Chinatown
    77,872
    185,050
    Aug 28, 2011
    Potential dating website.
  11. morlandoemtp
    morlandoemtp Light Load Member
    185
    95
    Jul 5, 2014
    New York
    Learn how to float gears,(look into an automatic company might be good for you too) also put your hand on the shifter, if you shift right you can do it lightly with 2 fingers easily but I don't suggest this, what I suggest is depending what gear you are going in, you should only be touching about 2 inches of your palm/hand lightly.(your fingers shouldn't be doing any work when you shift and doesn't even need to touch the shifter) Same with the steering wheel not too tight of a grip but the ability to take control of the wheel with both hands in case of a tire blowout. And like my boss use to say are you driving the truck or are you letting the truck drive you, most things you do should be smooth minimal effort while driving.
    Also besides doing all the good things for your health, I would consult a physician, and research remedies to combat arthritis.
