Spare switch output wire
Discussion in 'Kenworth Forum' started by tomcat5150, Aug 17, 2019.
  1. tomcat5150
    tomcat5150 Bobtail Member
    I'm trying to locate a power supply for lights I’m putting on the air cleaners on a 2019 T800. There are 3 spare switches on the dash. Are there wires capped off somewhere, preferably under the hood, that are powered through the spare switches?
  3. tnevin225
    tnevin225 Road Train Member
    1,166
    1,601
    Jan 1, 2014
    Pull the panel of and look behind the switch, I think they are probably just blank switches.
  4. HoneyBadger67
    2,056
    4,512
    Dec 15, 2018
    Savannah, TN
    There will be capped off wires behind the gauges or instrument panels. There will also be spare auxiliary wires to dedicated fuses that you'll be able to hook up your own switches to. If you're going to run LEDs, jus come off a wire in the headlight harness and they'll come on with your marker lights.
