Special Tools Checklist for HD Semi's
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Peterbilt379Fan, Sep 18, 2019.
  1. Peterbilt379Fan
    Peterbilt379Fan Bobtail Member
    Sep 17, 2019
    Other than the basic tools (e.g., wrenches, sockets, screwdrivers, pliers, etc.), what are the necessary special tools needed to work on semi's in heavy equipment/diesel mechanics? (for instance: battery, brakes, fuel lines, pullers, engine repair, drive-train, etc. etc.).
    On the other hand, what are some special tools that you absolutely do not need? For instance, tools and pieces that the tool trucks urge you to buy but you really do not need it, a shop does not even need to buy it, or a tool that eventually just gets tossed aside.
    Thank You Much for Your Knowledge
  3. A5¢
    A5¢ Medium Load Member
    389
    544
    Oct 30, 2017
    A really good torque wrench is super handy to have. Actually, two would be better. One for smaller torque specs and a big boy for the serious fasteners.
    Dino soar Thanks this.
  4. Dave_in_AZ
    424,232
    Fuel water separator wrench.
    Oil and fuel filter wrench attachment for a ratchet.
    Tire irons if you carry your own spares.
    Brake adjustment set for modern slack adjusters.
    Grease gun.
    Volt meter, continuity tester, test light.
    Socal Xpress Thanks this.
