Speed, Gears, Transmission......
Discussion in 'Trucks [ Eighteen Wheelers ]' started by thomas, Aug 31, 2008.
  1. 2fuzy
    2fuzy Road Train Member
    1,053
    324
    Jun 19, 2008
    Granite Canon,WY
    I have 98 fld same set up but with a 13 it gets 6.2-6.7 at 70mph just fyi
    buy the way a 10 over has a .74 final and a 13 has a .73
  3. 2fuzy
    1,053
    324
    Jun 19, 2008
    Granite Canon,WY
    also have a 01 classic with 3:50 and it gets worse mpg other wise the same
  4. sgreer78
    sgreer78 Light Load Member
    251
    62
    Jul 26, 2008
    St Louis, MO
    Since everyone else is doing it:
    I have an 03 Columbia, DD430, 13sp, 2.93 rears. 7.3mpg ECM lifetime.
  5. thomas
    thomas Light Load Member
    131
    13
    Jun 29, 2007
    Athens,Al.
    That is why I was looking at the option of a 13 double over. No power in the big hole just low rpm's and speed.
  6. 2fuzy
    1,053
    324
    Jun 19, 2008
    Granite Canon,WY
    double over gets you .86 on the low side of the spliter .73 on the high I was just pointing out that with a .74 in a ten it would be about the same final and cheaper in the end
    I love my 13s but a ten will get the job done just fine
  7. 2fuzy
    1,053
    324
    Jun 19, 2008
    Granite Canon,WY
    man that has got to be a slug in upper gears but nice when the fuel bills due
  8. droy
    droy Heavy Load Member
    828
    160
    Jun 11, 2008
    Iowa, LA
    One can't argue with those (mpg) numbers, however your last two gears must have cobwebs on them, or possibly your 13sp may not be overdrive, maybe direct, or even underdrive , eh?
    I'm running a 13 over with 3.36, on 24.5 standard height, and feel that I'm geared WAY to tall, especially in the hills. Even if I switched to 22.5, I don't think I would be at optimum specs for my truck.
  9. thomas
    131
    13
    Jun 29, 2007
    Athens,Al.
    Thanks for the info... That is what I was told to do"go with a 13 double over"..... that is why I am asking here... I need to lower the fuel bill but be able to still drive 70+
  10. sgreer78
    251
    62
    Jul 26, 2008
    St Louis, MO
    I believe 13th is .85 in this particular model. It actually pulls pretty good in top gear, drop it down to 12th and it's just fine. I have my cruise sat at 65 all day long and just every so often have to bump the brake to split it down one.
  11. thomas
    131
    13
    Jun 29, 2007
    Athens,Al.
    <------ Needs good suggestions on what to do. I have been running local so it has not been that big of a deal. I am going tomorrow to lease to a flatbed company that will take me out of the local market.
