speed limiter over-ride problem
Discussion in 'Trucks [ Eighteen Wheelers ]' started by eagle1016, Oct 17, 2018.
  1. eagle1016
    eagle1016 Bobtail Member
    Quick update clutch switch fixed issue worth Jake's and figured out how the previous driver got around ecm to over ride speed limiter i found two bad splicing s and 1 bad fuse now i have full speed and everything works. By the way as for the software to change ecm i do have it but the ecm is limited to 65 mph i can run as fast as i wish to thanks any way
  3. Blackshack46
    Blackshack46 Road Train Member
    Ok, this make a little more sense. Just a littlr. I take it the clutch switch wasnt allowing the jake brake to engage?
    That ecm thing, no comment.
