Speed sensor keeps failing randomly
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Volvo_780, Dec 16, 2022.
  1. Volvo_780
    Volvo_780 Bobtail Member
    26
    Feb 22, 2021
    I have 2011 mack cxu613 deleted having this issue my spend stops working cruise stops working and engine break stops working randomly if I turn the truck off everything goes back to normal within 10 miles it fails again sometimes I can drive 50 miles I replaced speed sensor and still having the same issue need your help
  3. '88K100
    '88K100 Road Train Member
    1,478
    3,526
    Aug 23, 2020
    I dont know,,i have company truck, speedometer quit working so no governor working and odometer not keeping score. I assume bad connection on mine since originally speedo would quit on wet roads and come back on dry road.
    loudtom Thanks this.
  4. VWbeagle
    VWbeagle Bobtail Member
    17
    11
    Dec 21, 2016
    We had a truck that had similar issues come through our shop. Turned out to being a tiny magnet from a speed sensor was stuck on the tone ring at the trans output. Every time the magnet would come around to the sensor it shut off cruise, throwing random codes.
    Coke driver Thanks this.
  5. Volvo_780
    26
    Feb 22, 2021
    Yeah replaced the speed sensor still having the same issue sometimes it just does it with the truck idling
