Speedo sender advice volvo
Discussion in 'Volvo Forum' started by MikeI, Dec 27, 2017.
  1. MikeI
    MikeI Bobtail Member
    8
    Swapped out a zf meritor automatic transmission to Eaton fuller 10 speed manual in 2004 vnl 670 with Cummins Isx. If I run the magnetic speed sender wires to ecm, will the dash and cruise get speed signal from the ecm??(after switching ecm to magnetic speed sensor and manual transmission). Or is it easier to add 1939 datalink speed sender? Brand of sender, tools needed for calibration if going to datalink sender. Thanks much
  3. Ridgeline
    22,768
    124,378
    Go talk to Volvo, they may have a conversion memo.
  4. MikeI
    8
    I did. 2 dealerships(no advice)?and can’t get through on the 800 number without a yearly subscription. It’s my fault they built a truck with a pos tranny that was only made 2 years Meritor auto is for sale if interested, needs throwout bearing
  5. Snailexpress
    2,675
    6,069
    Apr 28, 2014
    Rocky
    Sorry don't nave time to dig and digest it for you here is where you can find the answer.
    Volvo Trucks North America eMedia Center
    Type info in drop boxes - category electrical schematic, year, model and hit search
    On search result page click electrical schematics and you will be end here
    Screenshot-2017-12-27 Volvo Trucks North America eMedia Center.png Then click PV776-20018063 view online. It will download you 200 pages for all Volvo they made.
    All you need.
    If my memory still working speed sensor wires connected to VECU and from VECU by J1939 to Cummins ECM and by 1738 to dashboard and all other .
    Good luck
  6. MikeI
    8
    Thanks. I have the diagram. Wasn’t sure if the ecm sent the signal to the dash if using a magnetic speed sender. Or if it is all shared over J1939 Datalink from speed sender.
  7. nasriza
    nasriza Road Train Member
    2,409
    2,078
    Feb 1, 2013
    Chicago, IL
    its a 1939 datalink so even if you run to ecm it still wouldn't get it, you need to switch wiring harness between trans and cab need to go in with insite and switch speed parameter from 1939 to magnetic need to program tailshaft teeth and gear ratios in insite you will find in features and parameters portion then when all is said and done you will need a vehicle ecu from a volvo with 10 speed and cummins the only way to make it work properly
  8. nasriza
    2,409
    2,078
    Feb 1, 2013
    Chicago, IL
    y did you swap out the trans and if the old trans is good do you have any interestest in selling it i'm always looking for these type of transmissions.
  9. MikeI
    8
    We were sick of the issues with the automatic. Throw out bearing went out in clutch this go around so put a manual in it. Otherwise it was working fine. New voltage multiplier a couple years ago. Air Clutch would freeze up below zero, abs code would not allow auto shift, etc I’ll post for sale after we get the manual working correctly.
  10. nasriza
    2,409
    2,078
    Feb 1, 2013
    Chicago, IL
    take it from someone who has done this a few times on ZF pretty much what i wrotte down is the guide line how to make it work properly when you decide to post if for sale just pm me with price what you are looking for and location.
