Speedometer reads double actual speed
Discussion in 'Trucks [ Eighteen Wheelers ]' started by truckbiz, Dec 9, 2011.
  1. truckbiz
    truckbiz Light Load Member
    Thought I would run this one by you all,
    1998 Pete 378, 3406E, 18 speed
    I am no electronics wiz so this is driving me nuts, Speedo works perfect when I leave the yard and will do so all day UNLESS I shut the truck off. After starting back up the speedo will read at least double speed, usually faster, odometer and trip odometer both rack up double or more miles. When this first started I could usually stop, shut engine off, restart and all worked OK. As time went on of course it gets worse, but for awhile if I wiggled the speed sensor wires around (with engine off) it would work again. To me the funny part is that once it's working it works perfect unless you shut the truck off (I know, don't shut the truck off!!). Also it does not do this every time but it is getting more frequent.
    Any ideas? I am not just a parts changer, I would really like to know why. Thanks'
  3. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    sounds like internal dashboard issue
  4. Riverstick
    Riverstick Light Load Member
    186
    41
    Aug 26, 2011
    Ireland
    Either your sender unit at the gearbox or the speedometer unit itself....my guess is the speedometer head itself. The internal 'k factor' is adjusted and controlled by setting the DIL switches at the rear of the unit. I have seen several of these units go faulty over the years and do weird things like you outline.
  5. Heavyd
    Heavyd Road Train Member
    7,826
    6,276
    Feb 4, 2009
    Because the problem seems to change by keying on/off I would also say this is dashboard issue. If you have a good friend or someone you know with the same year you can try to swap out dash clusters for a couple of days and see if the problem follows the cluster. I am not sure on Petes, but the speed may be fed to the cluster from the engine ECM, so it may be having issues.
  6. truckbiz
    Well I would not have started in the dash, thats for sure! I'll open it up and look around.
  7. Shade Tree
    Shade Tree Light Load Member
    177
    44
    May 15, 2011
    Galloway Ohio
    98 Pete's should have a signal going to the speedo head and engine at the same time unless you have the two plug speed sensor on the back of the transmission. If it is a single the same signal will feed ECM and speedo head. Either way it sounds like one of the possibilities is a dash ground issue or you can get a shadow reading from the VSS on transmission if the sensor is adjusted too close to the gear. Those are easier to check then look at speedo head. I used to get trucks that would shopw vehicle speed just sitting still. CAT did come out with a in-line filter for the VSS that helped with this problem.
  8. Emulsified
    Emulsified Road Train Member
    3,663
    3,499
    May 6, 2010
    Dallas, TX
    Maybe you're just tired and are seeing double? :biggrin_25518:
  9. truckbiz
    This truck has two sensors on the back of the transmission. one @ 12 o'clock and one @ about 10 o'clock. I believe the speedo is the 12 o"clock one.
  10. truckbiz
    I never was very good with numbers!
  11. Shade Tree
    177
    44
    May 15, 2011
    Galloway Ohio
    The sensors are the same, try swapping if the connectors are the same and see if it still does it. Second is check the adjustment, I normally gave them an additional 1/4 turn out to stop the speedo issue..
