Spicer 10 speed shifter help - thanks!!!
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by alfio, Mar 11, 2022.
  1. Hammer166
    7,637
    27,986
    Aug 18, 2007
    ~8600+' and loving it!
    You're quite welcome. What a pain that you have to resort to doing all this...
  3. Definitivejames
    Definitivejames Bobtail Member
    10
    Aug 5, 2022
    Is there a certain name for that Val e between pilot and trans? Like a blow off valve?
  4. Hammer166
    7,637
    27,986
    Aug 18, 2007
    They called quick release valves in the brake system, but you don't one that large. They'll have in, out, and exhaust ports.
  5. Definitivejames
    10
    Aug 5, 2022
    Found them, thank you sir
    Hammer166 Thanks this.
  6. Dbrown86
    Dbrown86 Bobtail Member
    Hey I'm running in to the same issue do you have the part number of the valves you used and what you all did to get the eaton knob to work thanks
  7. MR Trucking
    MR Trucking Bobtail Member
    Can we please get an update on this? A YouTube video on how to convert an eaton fuller 10 speed knob into a spicer 10 speed knob would be epic, but I know I'm probably asking too much.
    Can anyone help with part numbers of items needed to do this modification and some steps?
  8. Hammer166
    7,637
    27,986
    Aug 18, 2007
    It's all up there ^. The referenced pilot valve basically is plumbed to replace the Spicer shifter, and the Eaton shifter just actuates the pilot valve.
  9. MR Trucking
    Appreciate it, do you know how many quick release valves are needed?
    Also, would these work?
    Part number for quick release valve:
    90054096
  10. Hammer166
    7,637
    27,986
    Aug 18, 2007
    Looks like it should. You'll need one on each output from the pilot valve. You could likely get away with something smaller if you can find it. Maybe search for 1/8" ports?
  11. Soflomase
    Soflomase Bobtail Member
    Sep 12, 2025
    To whomever this may help .. I found a cheap replacement pai makes a knob for a Mack truck that has 4 ports I’ve seen them go between 80 bucks to 160 … !!! I figured this out , because the previous owner of my truck had a Parker knob .. which I’ve never heard of and it seems they dont make them anymore, but it’s the same footprint. my guess is any four port for Mack will do … I hope this helps and they dont start raising the price on these !!
