Spicer auxiliary transmission
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Dino soar, Dec 1, 2018.
  1. Dino soar
    Dino soar Road Train Member
    4,790
    26,878
    Dec 8, 2017
    I have a Spicer 8041 auxiliary transmission in an old truck that I have.
    I was wondering besides the weight of it, how good or bad that would be behind the transmission in an F-350.
    I would rather have a 5831, but I don't know if I could find one or where to look.
    It has a 6.9 Diesel with a close-ratio 4-speed. It needs a lower gear to pull out when pulling a heavy load and needs to be able to split the gears.
    Are there any other alternatives?
  3. spsauerland
    spsauerland Road Train Member
    4,296
    10,886
    May 31, 2010
    West Harrison, In
    Not sure if still in business, but used to be a two speed box underdive or overdrive box made by company called gear vendors. Buddy had one in a Chevrolet 3500 dually that worked pretty slick.
    Oxbow, BoxCarKidd and Goodysnap Thank this.
  4. BoxCarKidd
    BoxCarKidd Road Train Member
    4,448
    6,492
    Aug 26, 2014
    I do not recall the brand but I put an O/D unit in place of the tail housing on a Dodge with an auto.
    Oxbow Thanks this.
  5. Dino soar
    4,790
    26,878
    Dec 8, 2017
    Well, because it is a 4-speed close-ratio low gear is kind of high and high gear is one to one.
    So really I need a lower low for pulling out and, I need to be able to split the gears, and then overdrive because high gear is one to one.
    So I really need low direct and Overdrive.
    BoxCarKidd Thanks this.
  6. Rubber duck kw
    6,092
    17,685
    Dec 9, 2017
    It doesnt have granny low four wheel I'm guessing?
  7. BoxCarKidd
    4,448
    6,492
    Aug 26, 2014
    I 6 spd out of a latter model truck would be easier.
    Oxbow Thanks this.
