Canadian driver here, had a question about the 8/2 sleeper rule. I'm driving to Maryland tonight which is 500 miles from the company terminal. Need to be there for 15:00 tomorrow.
Last time I tried split sleeper I drove 8 hours and stopped for 8 hours (sleeper) my Qualcomm showed I only had 2 hours of drive time, ended up waiting the full 10.
Not too familiar with sleeper split, only done it once with my trainer and that was it.
How would I do sleeper split if I was leaving at 20:00?
Split sleeper question.
Discussion in 'Questions From New Drivers' started by Canadianhauler21, Jul 10, 2018.
Think of the 8 in SB as just pausing your 14. Whatever you have when you stop for the 8 is what you will have when the 8 is up. You don't get anything back until you take the other 2. when you finish the other 2 you will get hours back minus the hours you used between the 8 and 2.
Canadianhauler21 and skittlz Thank this. -
Split sleeper dosnt give any time back it simply freezes your 14 at whatever it was when u started your break. It's very rare that's it's useful at all, usually only to catch back some time lost sitting at a dock or broke down if you had the foresight to log the whole thing as sleeper.
skellr and Canadianhauler21 Thank this. -
skellr Thanks this.
Spits are a usually a PITA. You can also do a 2/8 split if you have 2 hrs off-duty getting loaded or something, or if you sit for 5 hours getting loaded, you could go to sleep for 8 and have the same hours left as what you had when you arrived ( after on-duty time checking in of course
They kinda need to be started early on in the trip, and the 8 has to be logged as SB to pause the clock.Canadianhauler21 Thanks this. -
