Split sleeper question
Discussion in 'Questions From New Drivers' started by jterry1556, Dec 27, 2023.
  1. jterry1556
    jterry1556 Light Load Member
    73
    59
    Oct 6, 2022
    I’m not sure if I understand split sleeper correctly.
    So I just ran a full 11 hours and I changed my ruleset over to split sleeper setting. Does this allow me to rest for 8 hours and then I will have some time to run then I will have to take another 2 hour break? Is it this easy?
  3. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,769
    Mar 5, 2012
    Ontario Canada
    No. You used up all available driving time (11) for this shift, you are now required 10h off.
    Say you only used 10 then went in sleeper. 3h later it would grant you only 1 more hour then require at least 7h sleeper. Following the 7h sleeper it would give you 10h back again.
    NightWind Thanks this.
  4. Iamoverit
    Iamoverit Road Train Member
    2,159
    4,957
    Oct 31, 2023
    Your drive time can't be more than 11 hours total between your two breaks.
    jterry1556 Thanks this.
  5. jterry1556
    73
    59
    Oct 6, 2022
    What if I take the 7/8 hour first?
  6. gokiddogo
    8,786
    14,769
    Mar 5, 2012
    Ontario Canada
    If you drive for say 7 hours then take a 7 or 8 hour break it will give you back 4 (11-7) before then requiring a 3 or 2 hour sleeper again, then your first driving time of 7h falls off and the calculation is 11-4=7 available again.
    goga, bryan21384 and jterry1556 Thank this.
  7. bryan21384
    bryan21384 Road Train Member
    15,757
    34,341
    Sep 18, 2009
    Memphis, TN
    The point is, you need available drive time. If you drive the whole 11, the split sleeper is useless. You can do that as long as you have drive time. The previous post laid it out perfectly.
    tscottme and gokiddogo Thank this.
