spliter acting weird
Discussion in 'Flatbed Trucking Forum' started by DONDAMIAN, Jun 11, 2013.
  1. DONDAMIAN
    DONDAMIAN Light Load Member
    54
    16
    Feb 25, 2013
    nj
    I have a 98 century class with a meritor that's the brand on the stick the splitter started acting weird. at first it would give me a hard time trying to go back on low speeds the problem has gotten worse. I was coming down to Florida half loaded and going through scales a couple times I had to stop and then, to put the truck on gear again, I would have to start up on high gears. It would make that characteristic noise of when you try to force high gears into lows or viceversa once it reaches full speed the problem seems to be gone but it would come back anytime without following any particular patterns
    Now I'm empty and when I stop at a traffic light or something I can hear the splitter is getting engaged and disengaged by itself.
    While I'm waiting for my trailer to get fixed I'll be going to the Mechanic today but I'd like to have an idea of what are the most common diagnoses to spliter problems and prices of parts
    Thanks for reading and for your opinions
  3. MJ1657
    MJ1657 Road Train Member
    7,521
    50,152
    Jan 28, 2012
    Isanti, MN
    You might want to post this down in the garage section.
    VisionLogistics and Flightline Thank this.
  4. silenteagle
    silenteagle Road Train Member
    1,491
    795
    Oct 23, 2011
    Ozark, MO
    This starts happening when there is alot of water in the air system.
  5. Jumbo
    Jumbo Road Train Member
    3,669
    7,389
    Sep 4, 2009
    Appleton, Wisconsin
    So are your straps inside or outside of the rubrail?
  6. Casual Trucker
    Casual Trucker Medium Load Member
    495
    326
    Sep 7, 2012
    You May want to check your air dryer filter the new ones cost around $75 It's located near your air tanks at the bottom of the truck and looks like s fuel or oil filter
    DON'T TAKE IT OUT BEFORE DRAINING ALL THE AIR PRESSURE IN THE SYSTEM OR JUST HAVE QUALIFIED Mechanic do it
  7. Passin Thru
    Passin Thru Road Train Member
    1,918
    565
    Mar 8, 2007
    VA
    Take the top off the shifter and oil it also.
  8. Freightlinerbob
    Freightlinerbob Road Train Member
    2,234
    1,316
    Jan 15, 2012
    West Coast B.C.
    I've had a similar problem and it was transmission lube oil getting past a bad gasket and into the air cylinder. Is there an oily film on or around your shifter?
