Splitter splits rough
Discussion in 'Trucks [ Eighteen Wheelers ]' started by MacGyver., Sep 5, 2011.
  1. MacGyver.
    MacGyver. Light Load Member
    55
    16
    Apr 6, 2010
    minnesota
    Hi everybody. I have a question I hope I could get some help with. I just picked up a used truck a few weeks ago. Its a 2006 Pete 379 and has a 550 acert and a 18 speed. I have found that the splitter has a few issues.
    It works decent on the low side, but when on the high side shes a rough one. When in 5th and I split the gear it does not glide in, it down right slams in hard enough to shake the whole truck. Then when I am in in 5th over and I am ready to go to 6th I move the splitter back down and before I even get my foot off the throttle and the shifter half way out of 5th the splitter will slam right back into 5th direct. Which in turn revs up the motor and cant be any good for the drive line. It does the same in 6th, 7th, and 8th just not as rough.
    I asked the guy about it at the dealership and he said it has to do with the acerts running so hot. He said that since the motors run hot the air compressor is that much hotter which makes the air in the air system that much hotter. He said the hot air drys out the o rings around the splitter actuator. His idea to fix it was to tell me to pull the cover off the splitter on the back side of the tranny and shoot some 3 in 1 oil in it.
    I am wondering what else it could be or what else can be done to fix it. I do have the tranny fluid dropped right now (it was burnt pretty badly and had to put a PTO on). Not sure if it helps any but the truck has 650,000 miles on it and the truck has sat for the last year due to the previous owner going out of business and the last driver overheating the motor and needing a rebuild. Thanks in advance for any help I appreciate it.
  3. bender
    bender Road Train Member
    2,105
    1,361
    Jul 20, 2010
    Don't Kid Yourself
    Sounds like the pressure regulator on the trans has failed. It should limit pressure to 60-65 psi to prevent the harsh shifting that you describe.
    They may have rigged it that way to compensate for a worn out synchronizer assy to keep it from grinding while making a shift.
    The salesman story sounds like just that, a story.
  4. Nevs
    Nevs Light Load Member
    295
    107
    Dec 25, 2010
    flyover country (Iowa)
    I agree, I have an Accert and mine doesn't shift that way. (RTLO18918B)
    Sounds like a BS excuse to me.
  5. pullingtrucker
    pullingtrucker Road Train Member
    1,185
    598
    Dec 21, 2008
    Fostoria, Ohio
    The guy at the dealership is a idiot and I wouldn't take his advice again. Yes the ACERTs do run hotter, but the only o-rings that are effected by the additional heat are the ones in the unloader valve in the compressor head. I agree with the others that it is more than likely the pressure regulator.
  6. oneshot
    oneshot Medium Load Member
    626
    248
    Feb 28, 2009
    mississippi
    Come on PT,U know those guys at the dealership are ASE certified.:biggrin_25523: But it does sound more like the regulator than alot of Hot air.Hey I just made a funny.:biggrin_25525:
  7. pullingtrucker
    1,185
    598
    Dec 21, 2008
    Fostoria, Ohio
    To be honest...the ASE certification doesn't mean much anymore. To me it just says "Good job, you passed a test but still have no real world experience".:biggrin_25523: Sorry, but I had a recent bad experience with a "ASE certified mechanic" lately.
  8. Prairie Boy
    Prairie Boy Road Train Member
    3,258
    1,914
    Nov 18, 2010
    Edmonton, AB
    The salesman is spewing a lot of hot air himself. Doesn't matter if the air is hot or cold, the pressure is consistent.
    aiwiron Thanks this.
  9. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    seems to me it is splitter syncho issue (I sugest 18 st tranny got two synchros only - range and splitter synchros).
    But sometimes synchro work bad with old tranny oil. It is easier to feel on full synchro transmissions. And changing oil may solve the problem.
    if not... splitter is just a two gear input shaft so to pull it out you need to drop tranny and unbolt and remove input shaft.
  10. MacGyver.
    55
    16
    Apr 6, 2010
    minnesota
    I knew "take it apart and shoot some 3 in 1 oil in there" was not gonna be the cure. Which is way I brought my question here. There is a lot more experience and knowledge on this forum than in most shops. I plan on taking the cover off and at least looking in there to see if its anything obvious.
    Well I learned something new today than. There is a pressure regulator for the splitter. Where is the regulator for the splitter located maybe I can swap out that one and put my new one on there from the PTO to test it out. That is if it is a 65 psi regulator like the one for my PTO.
    I did a forum search on this subject to and the only other thing I could find that could be it was from a post from Beltrans in which he said "My 18-speed did it to me once in a while mostly when I splitted 5th gear. when it did it my whole truck would shake. A local gear guy told me to replace a spliter valve cover for an updated one with smaller orifice holes. Replaced it a week ago and it shifts really good. It is on a back of a tranny just below a driveline on a drivers side with one small airline and another bigger hose going to it. The price is around $90."
    I plan on looking into that too and seeing if that is something that could need updating or just replacing on my tranny.
    Thank you all for your input I greatly appreciate it.
  11. MacGyver.
    55
    16
    Apr 6, 2010
    minnesota
    Ok here is my next question. When I take that little cover off the back of the tranny tomorrow for the splitter well I be able to see the synchros and tell if they are all chewed up or wont I be able to see them. The fluid is dropped in my tranny right now so I can look into the 6 and 8 bolt covers for PTO mounting if need be to look inside.
