Spn 247 fmi 14
Discussion in 'Freightliner Forum' started by jsnell, Oct 5, 2021.
  1. jsnell
    jsnell Light Load Member
    253
    343
    Apr 12, 2016
    Check engine light is on. This is my first emissions truck. Tried to clear the code with otr device. Light still on. I was told to drive it and it should clear. Does this sound right or should I take it to a dealer. Thank you
  3. SWM_TECH
    SWM_TECH Light Load Member
    139
    145
    Apr 15, 2018
    Fault description says diagnostic is typically Aftertreatment Control Module (ACM) reported ash mileage is lower than the Common Powertrain Controller (CPC) stored value. It would appear you need Detroit Diesel Diagnostic Link (DDDL) to set the ash volume.
    Here is the fault description & diagnostic steps.
    RocketyMan Thanks this.
  4. jsnell
    253
    343
    Apr 12, 2016
    Thank you, I hope I got some time before I have to have it reset. I have 250 more miles on this load.
  5. jsnell
    253
    343
    Apr 12, 2016
    Got load done. Called support at OTR, turns out I wasn't using the product correctly. They walked me through it and the light is off and all faults are cleared.
  6. Raptrans
    Raptrans Bobtail Member
    What did they tell you to do mine is the same way
  7. joseph1853
    joseph1853 Road Train Member
    1,003
    562
    Dec 12, 2010
    Waco, TX
    They probably told him the key must be in the on position with the truck off to clear codes. He probably tried to do it with the truck running.
  8. jsnell
    253
    343
    Apr 12, 2016
    I don't remember but support was great
  9. joseph1853
    1,003
    562
    Dec 12, 2010
    Waco, TX
    yeah, it was a while ago but I figured it could help someone else.
    jsnell Thanks this.
