So recently this code has come on after hearing my truck out the shop for a new clutch. I see air bubbles in the fuel water separator as well. Is there an easy fix for this?
Spn 157 fmi 0 is also inactive now
Spn 3055 fmi 0
Discussion in 'International Forum' started by Twista89, May 25, 2021.
Both those codes are for fuel rail pressure being too high. Could have a restricted return line or a bad pump. Wouldn’t hurt to fix the air in the system and see what happens.
So I put some fuel cleaner in which restored some power and temps started to return to normal. I figured it was bad fuel but now this morning I wake up to the fuel water separator being empty and I had yo prime the engine. It runs fine with full power but I have to keep priming thr motor if I turn it off. No hard starts or misfires. The separator is also empty while running as well.
Still probably getting air in there which causes the fuel to drain back. Check all your voss fittings on the suction side, including tank fitting o-rings. Worst case you have a cracked stand pipe on the tank.
