SPN-402942 ? I can't find this code listed anywhere
Discussion in 'Volvo Forum' started by Texan4Life, Jan 10, 2024.
  1. Texan4Life
    Texan4Life Bobtail Member
    44
    16
    Oct 18, 2022
    2012 VNL D11 700k miles
    I'm having SPN-4094 (nox limits exceeded) issues that come and go. If I drive long enough it will clear and remove the derate. And then usually the same day or next day I'll get derated again. One code that has shown up in Motive is a few of these 6 digit SPN codes. I can't find any information on them anywhere. I have had up to 6 or 7 of these codes at once. The current one I have is SPN-402942 FMI 9
    I also had two codes for open circuit on the EGR temp and EGR differential pressure sensor. I had my engine wiring harness replaced last year so I have a hard time thinking its a wiring issue. So today I replaced those and also the boost sensor also.
    Other than the bolt on the frame rail behind the batteries are there any other ground points I should be looking checking/cleaning? I have also replaced the DEF doser valve which has not helped. I also removed and cleaned the Venturi tube in an ultrasonic cleaner (it wasn't that dirty)
    any thoughts and opinions will be most helpful!
  3. JB7
    JB7 Road Train Member
    1,020
    1,808
    Dec 13, 2022
    Laurel, MD
    Plenty of Volvo 4094 info online but not with FMI 9. It would be best to have someone connect the proper software to not only get any codes but the data such as sensor readings etc.
    2 things control NOx, the DEF fluid and the SCR (Selective Catalyst Reduction) which is a catalytic converter like in a car. The DEF fluid is injected at the inlet of the SCR. Eventually the materials (catalyst) in the SCR wear off, become inert, and don't take care of NOx emissions. Given your 700k miles the SCR is at or near the end of its life. There are other threads discussing this on TTR. You are likely looking at a one box.
    AModelCat Thanks this.
