Spread axle trailer not level
Discussion in 'Ask An Owner Operator' started by 93fla, Apr 18, 2020.
  1. 93fla
    93fla Bobtail Member
    37
    13
    Aug 27, 2019
    I have a spread axle drop deck 48x102 n my truck is a 93 freightliner truck n trailer are air ride
    The problem is my trailer always look to have more weight on the front axle n the back one always has the air bags with more air
    Looks like my truck is to low for my trailer?
  3. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,144
    Mar 5, 2016
    White County, Arkansas
    Did you put a carpenters level around the deck and see?
  4. Hegemeister
    Hegemeister Road Train Member
    1,912
    1,660
    Jun 16, 2012
    Mechanicsburg, PA
    Is the front of the deck and rear of the deck an equal distance from the ground?
  5. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    You may have a super/low 5th wheel that is so close to the frame that it will not tilt, it just sits flat. You may get some square tube and have it weld to lift up 5th wheel, or buy a hi 5th wheel slider, and put your 5th wheel plate on the hi slider?
    Farmerbob1 and Deere hunter Thank this.
  6. HoneyBadger67
    2,056
    4,512
    Dec 15, 2018
    Savannah, TN
    I don't think I'd use tubing. While it might be cheaper, two pieces of 3/4" flat steel would be stronger. Weld the two pieces together and then have them bolted between the 5th wheel and frame.
  7. HoneyBadger67
    2,056
    4,512
    Dec 15, 2018
    Savannah, TN
    A level wouldn't do any good, flatbed are crowned.
    D.Tibbitt Thanks this.
  8. FoolsErrand
    FoolsErrand Road Train Member
    2,877
    12,169
    Sep 15, 2017
    Put a prybar under each trailer tire where the tread meets the dirt and crank into it while someone watches from underneath to see how smoked your trail arm bushings are. If they rock a bunch youre onto something.
  9. Spyro2112
    Spyro2112 Medium Load Member
    623
    433
    Mar 17, 2018
    Does the trl have 24s and the truck 22s
    Farmerbob1 Thanks this.
  10. Old Man
    Old Man Road Train Member
    4,597
    13,471
    Apr 3, 2009
    Oklahoma City, OK
    With a load on weigh the spread, on a cat scale put from axle on drive platform and back axle on trailer platform.
    They should be within a few hundred pounds,you will know if you have a problem or not.
    Some states will check the balance on a spread, bad news if you have 23k on one axle and17k on the other.
    Farmerbob1, Lostkeys and D.Tibbitt Thank this.
  11. kwswan
    kwswan Road Train Member
    2,028
    11,077
    Jul 26, 2009
    mcminnville,tn.
    You missed the part about it being a drop deck.
    Hegemeister Thanks this.
