Spread axle trailer tires which one??
Discussion in 'Ask An Owner Operator' started by RTR, Aug 8, 2017.
  1. RTR
    RTR Light Load Member
    194
    49
    Alabama
    Trying to figure out and get advice and suggestions on which one last and the best?
    And if you have any luck on running Recaps from your virgin tires being capped?
  3. LoJackDatHo
    LoJackDatHo Medium Load Member
    446
    752
    Jan 26, 2017
    I've always heard you can't beat continental tires for spreads.
    mslashbar Thanks this.
  4. RTR
    194
    49
    Alabama
    Any particular brand name or model number they're on the Continental??
  5. mtoo
    mtoo Road Train Member
    1,942
    4,528
    Jan 15, 2011
    Retired on bended knee
    Michelin XZE ran them for years, great spread axle tire.
    jamespmack Thanks this.
  6. DL550CAT
    DL550CAT Road Train Member
    1,427
    1,484
    Oct 18, 2009
    Waynesburg, Pa
    Continental HSR. I use to run very heavy on a spread (60,000#). XZE made to 35,000 miles on the rear axle HSR would go to 70,000+. I would cap the casings 1 time. Usually would go to the drives but I did at times cap the trailer too. I never had one let go nor did I ever peel a cap off.
    EdwinTheGreat218 and LoJackDatHo Thank this.
  7. mtoo
    1,942
    4,528
    Jan 15, 2011
    When I tried the HSR they started cupping. I went back to the XZE's. They performed better for me. A lot of guys swear by the HSR's and they are cheaper. I bought 8 of them, ran that set out, then went back to the XZE's.
    edit: If you only get 70,000 miles out a set of spread axle tires, your working that trailer way harder than I ever worked any of my spreads. ( I missed the 60,000# part)o_O
    jamespmack and Ruthless Thank this.
  8. DL550CAT
    1,427
    1,484
    Oct 18, 2009
    Waynesburg, Pa
    Yeah only a 27 mile trip with several hard 90 turns. It was not uncommon to have 76,000 on the deck.
    Ruthless, Cat sdp and mtoo Thank this.
  9. Hurst
    Hurst Registered Member
    6,618
    12,266
    Aug 24, 2011
    Tampa, Fl
    BFG ST230 have been the best tire on spread for me (with a reasonable price). I get them for $343 a tire through my carriers account with Pomps.
    I'm seeing about 140k mi on them running my spreads open 99% of the time. No lift axle. Just a dump valve on rear axle that I use when parking.
    Hurst
    bowhunter67 Thanks this.
  10. spyder7723
    spyder7723 Road Train Member
    15,468
    25,078
    Mar 31, 2013
    sarasota, fl
    I heard that for two decades. Never believed it. Finally gave them a try july of last year. A year later it looks like i put them on last week. But good luck finding them. Hsr2 is the tire you want. Or the hsr2 ecoplus. Same tire just less tread depth.
    LoJackDatHo Thanks this.
  11. mslashbar
    mslashbar Medium Load Member
    605
    826
    Jul 22, 2009
    elizabeth,co
    They replaced the HSR2 with the HA3. Pretty much same tire with a new model number.
    spyder7723 and LoJackDatHo Thank this.
