Spread or Tri
Discussion in 'Flatbed Trucking Forum' started by bonder45, Mar 16, 2020.
  1. bonder45
    bonder45 Road Train Member
    1,803
    5,452
    Oct 2, 2011
    Williston, ND
    Coming to North Dakota expecting to haul water and I’ve been on a flat bed 80% of the time. I wouldn’t be upset expect I have to give another 10% of my gross so I’ve decided that maybe I should throw a few dollars and buy one!
    I’m just trying to play my long game and cover myself whether on flat bed or tanker.
    Im looking for some insight of the difference between a Tri and spread axel flat bed.
    pros, cons, etc - help fill me in!
  3. FoolsErrand
    FoolsErrand Road Train Member
    2,877
    12,169
    Sep 15, 2017
    If you will only haul legal weight then a triaxle is at a disadvantage because the 3rd axle comes out of your payload. If you will haul OSOW then you can permit more on the triaxle.
    Bean Jr. and Rcranch81 Thank this.
  4. magoo68
    magoo68 Road Train Member
    3,393
    5,385
    Jun 11, 2011
    st malo mb canada
    Do you expect to cross into Canada in the future if so the spread can only load the legal weight of a single axle . Plus you need to raise it off the ground. Tri axles ride nicer but have more tires to maintain .. if your riding on rough roads I’d go with the tri because it has less weight per axle which is easier on the suspension .PS in a hard panic braking situation the tri axle stops way shorter.
    FoolsErrand Thanks this.
  5. bonder45
    1,803
    5,452
    Oct 2, 2011
    Williston, ND
    I think I will just be in ND and MT hauling pipe and equipment mostly.
    Actually I’m going to say 95% pipe.
    D.Tibbitt Thanks this.
  6. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,144
    Mar 5, 2016
    White County, Arkansas
    I like 10 foot spreads myself. You can put 20K a axle back there. The Tri probably can load a little more but increases maintaince. Its sort of a compromise.
    If I had a choice it will be a Ravens 48 foot with 10 foot spread and Coil package. It can and did scale 52000 pound coils in her time with my experience first hand. I recognize that ravens is a older trailer and may not be made anymore. But that is the flatbed I pick first and compare against all other flatbeds out there. The arch bridge is a minor annoyance when hauling custom built hand built special machinery orders. (Covered wagon)
    The tractor however will have to have triple axles and disc brakes if I had a need of one. Not the standard tandems. There are just too many times the weights on the drives tip past 34000 and we have to constantly fuel 50 gallons until past a nazi scale.
  7. snowwy
    snowwy Road Train Member
    20,612
    13,333
    Jul 6, 2009
    Provided the spread is 10ish feet. You can haul 40k. If it's 9ish it drops you to 39. 8ish drops you to 38.
    A tri gives you 43,500. Give or take. Depending on the bridge of the 3 axles. Could be higher.
    That's a standard federal weight. ND and MT might have a different weight allowance. Up or down.
    x1Heavy and FoolsErrand Thank this.
