Spring pins
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Perchie15, Jul 14, 2024.
  1. Perchie15
    Perchie15 Light Load Member
    253
    75
    Aug 16, 2021
    What style is the better one to go with? The screw type with greaseable pins or the non greaseable?
    I believe the greaseable work better cause you can always maintain it but the non greaseable has the rubber bushing in it so I’d think that would work as good. What’s your take?
  3. AModelCat
    164,923
    Back in the mid 2000's is roughly about when KW started putting the non-greasable rubber bushings on the steer axle. Shop I worked at converted a bunch of newer trucks back to the threaded, greaseable pins.
    Rubber bushings are probably fine on a highway truck but they didn't make it very long in the bush.
    Diesel Dave Thanks this.
  4. ElmerFudpucker
    7,039
    76,999
    May 17, 2024
    Roller bearing pins are best
  5. Perchie15
    253
    75
    Aug 16, 2021
    I have not seen this style hmm.
  6. ElmerFudpucker
    7,039
    76,999
    May 17, 2024
  7. Rideandrepair
    17,574
    56,926
    Aug 8, 2015
    Surprised Horton doesn’t show what makes them so good. The roller bearings are long needle bearings running the whole length of the pins. I had them installed on my 92 WS in around 1997, with new hanger brackets, old ones were eggholed. Didn’t bother changing the front bushings, they barely move, usually don’t wear. I recall the warranty being an odd number. 487k maybe. Something like that. Lol
  8. wichris
    wichris Road Train Member
    4,507
    9,281
    Jan 17, 2011
    Used to run the Horton rollers in all the older Pete's. As soon as I picked up the trucks they were installed before going out.
  9. Mr Bob
    Mr Bob Light Load Member
    269
    84
    Mar 17, 2015
    uh, greaseable pins require greasing before they clog up so if you dont have the time to do it they wont last.
