Squirrel Pull
Discussion in 'Flatbed Trucking Forum' started by Solo_Jedi, Sep 5, 2022.
  1. Solo_Jedi
    Solo_Jedi Bobtail Member
    9
    9
    Aug 29, 2015
    Massachusetts
    I'm having issues pulling a flatbed with a Moffet on the back. It feels like the trailer is going all over the place once I get over 50 MPH on some roads. The 5th wheel is set in the middle. The trailer has both RSA and Skid tires. I just want to know if there is a correction or if this is common.
    Kyle G. Thanks this.
  3. Ruthless
    Ruthless Road Train Member
    9,191
    91,269
    Aug 28, 2010
    The City.
    Put weight over the fifth wheel
    Some manufacturers add weight plates under the deck between the stubs over the fifth wheel. Some people put a flat piece of steel 4’x8’x1” and bolt it to the deck with countersunk bolt holes to correct it, if you have a spread axle, put a lift on the front axle and that will help when empty.
    larry2903, beastr123, MOBee and 4 others Thank this.
  4. Solo_Jedi
    9
    9
    Aug 29, 2015
    Massachusetts
    Is there too much weight on the tail? I also have a claw strapped to the back for picking up cubes of brick pavers. I suppose I can strap that up front over the fifth wheel. Thanks
    beastr123 and Kyle G. Thank this.
  5. Ruthless
    9,191
    91,269
    Aug 28, 2010
    The City.
    It’s not that there’s too much on the tail, it’s that there’s that much on the tail and none on the nose to compensate and hold it down// Hauling pavers I bet they don’t want to add a whole bunch of weight as it will cut the product load.
    UTT?
    kylefitzy, cke, larry2903 and 3 others Thank this.
  6. Kyle G.
    Kyle G. Road Train Member
    3,902
    20,578
    Jan 23, 2016
    Eastern Iowa
    I have found that sliding the 5th wheel all the way back to maximize wheelbase helped a lot.
    Solo_Jedi Thanks this.
  7. Solo_Jedi
    9
    9
    Aug 29, 2015
    Massachusetts
    I don't know what UTT means. I will try placing the claw over the 5th wheel. It's pretty heavy. Thanks for your input. It's appreciated
    blairandgretchen Thanks this.
  8. Ruthless
    9,191
    91,269
    Aug 28, 2010
    The City.
    utt does a lot of unilock pavers out of uxbridge
    cke and Roger McG Thank this.
  9. Solo_Jedi
    9
    9
    Aug 29, 2015
    Massachusetts
    No. Quikrete. Lakeland
    cke and Ruthless Thank this.
  10. kranky1
    kranky1 Road Train Member
    2,253
    8,855
    Sep 16, 2015
    Ontario, Canada
    For pavers I’d have that lift on a top mount right over the middle light of the trailer. Natural and manufactured stone you can give up that deck space easily and still get up to weight. Ride better and won’t beat up on the lift so bad on the empty cycles.
    kylefitzy Thanks this.
  11. Espressolane
    18,690
    117,153
    Do you have wide base singles for drives and/or trailer?
