SSB CB Radio
Discussion in 'CB Radio Forum' started by Sgonza101, Mar 15, 2018.
  1. Sgonza101
    Sgonza101 Light Load Member
    136
    28
    Mar 10, 2018
    What cb radio should I get that has SSB? I'm looking at the United bearcat 980 for $120 or any other cb with ssb like the Galaxy. I do plan on modifying it a bit for longer range so take that into consideration. I've heard of modifying an armature radio to run cb, I think the galaxy brand can do that. Of course with ssb.
  3. Night Stalker10
    Night Stalker10 Road Train Member
    1,697
    1,271
    Jun 26, 2017
    I have never owned a bearcat 980 CB radio, but from reading reviews from the guys who do own them, they are very happy with the radio. As far as modifying the bearcat 980, there’s not much you can do to it. It has what they call surface mount components inside, so that really limits you as to what you can do with it.
  4. Night Stalker10
    1,697
    1,271
    Jun 26, 2017
    It sounds like you’re new to CB radios. As far as converting a ham radio to run on the 11 meter band, I wouldn’t recommend you going that route. It will cost you a lot of money to have the radio converted to the 27 MHz frequency and have a tech do a proper alignment on the radio. Not to mention the initial cost of the ham radio itself. I would recommend staying with the bearcat 980.
  5. Timin770
    Timin770 Road Train Member
    1,658
    1,759
    May 27, 2011
    Canton, GA
  6. Sgonza101
    136
    28
    Mar 10, 2018
    Supposedly this one RCI-2970N2 is really good on Ssb and am. With 200 watts.
    Tall Mike Thanks this.
  7. lilillill
    lilillill Sarcasm... it's not just for breakfast
    5,642
    13,472
    Nov 7, 2007
    Possum Booger, Alabama
  8. Night Stalker10
    1,697
    1,271
    Jun 26, 2017
    Okay, so I assume money isn’t a problem? I thought maybe it was since u started the thread with a bearcat 980.
  9. Ridgeline
    22,724
    123,385
    Just go get something simple, cobra or Uniden and learn how to use it.
  10. stacks
    stacks Road Train Member
    1,547
    850
    Oct 27, 2011
    Emerald Isle
    stryker sr955 all the way
  11. delta5
    delta5 Road Train Member
    1,193
    7,404
    Sep 9, 2010
    Rci 2950dx if you can't run the heavy wires to the bat for the 2970n2. 2950 is the 2970n2 without the built in 300w amp.
