Stall Selection Criteria
Discussion in 'Truck Stops' started by Graham Cracker, Dec 28, 2022.
  1. Graham Cracker
    Graham Cracker Light Load Member
    114
    26,394
    Nov 12, 2022
    When I walk into the truck stop restroom and I need to sit and stay a minute and I’m looking for a good stall I’ll look at the first one and if it’s really clean that’ll do. If it’s not perfect I look at the next and the next and I’ll select the cleanest of the available ones. Now it can be conflicting if there’s a real clean stall and right next door is a guy that’s blowing out burritos. Do I go a few stalls down to obtain privacy and space away from the human sewer pipe over there to a dirtier stall or do I go for the clean stall and just try to hurry.
    How do you make your selection?
  3. Moosetek13
    Moosetek13 Road Train Member
    14,994
    19,060
    Nov 1, 2010
    Burnsville, MN
  4. 50WT
    50WT Road Train Member
    3,071
    28,273
    Dec 26, 2015
    Depends on how badly you need to go . If you've got jumpers at the door then any one will do.
  5. tscottme
    tscottme Road Train Member
    On the advice of 2 NFL quarterbacks & my State Farm agent I learned that a rigorous program of yoga will end the need to use any restroom.
  6. ZVar
    ZVar Road Train Member
    10,911
    23,833
    Sep 10, 2010
    Flint, MI
    There was a mythbusters episode about the cleanest stall.
    Basically everyone passes the first one because everyone thinks it's the most used. In reality since everyone passes it, it's the least used one.
  7. Graham Cracker
    114
    26,394
    Nov 12, 2022
    It’s tough when you got a guy with projectile diarrhea in stall 1, and stall 2 is nice and clean and further down the stalls are all dirty.
    What to do ?
  8. ZVar
    10,911
    23,833
    Sep 10, 2010
    Flint, MI
    You wash your feet in the sink!
  9. Capacity
    Capacity Road Train Member
    1,499
    3,119
    Jul 28, 2019
    Neenah Wi
    I pick the one that dosen't have a hole drilled in the dividing wall with over the tank Frank tap dancing on the floor in the next stall.
  10. CargoWahgo
    CargoWahgo Road Train Member
    3,912
    3,945
    Jan 10, 2012
    Louisville, Kentucky
    Doesn't matter I'm still ripping off a ton of toilet paper and putting it on the seat.
    If it's dirty I'll just spit on it and give it a wipe real quick.
    My dad was in the army and refused to wipe his ### and it was on top of the seat for some reason so I was trained for it.
  11. Dennixx
    Dennixx Road Train Member
    4,549
    14,644
    Feb 13, 2010
    twin cities
    Identify as a woman and use the other bathroom.
    It may or may not be as horrific.
    Or identify as a bear and go into the woods behind the joint.
    Crude Truckin' Thanks this.
