Stange Volvo d12 behavior...
Discussion in 'Volvo Forum' started by Volvo8873, Nov 4, 2016.
  1. Volvo8873
    Volvo8873 Light Load Member
    240
    145
    Apr 27, 2016
    Western Wisconsin
    2005 Volvo d12 VN day cab
    Computer set at 400 hp
    3.73 gears
    10 speed
    Blixxton power box
    Trying to figure out something about this truck. When loaded 75000 pounds it it runs and pulls pretty #### good. But when I pull with a empty flat the truck does not have as much power as it does loaded.
    Fuel mileage is great and everything checks out. I am starting to wonder if there isn't some parameter to govern power when there is load on it? The truck use to be a fleet truck with the speed limited to 65mph 1600 max rpm etc. but have been removed since.
  3. cumminskid123
    cumminskid123 Light Load Member
    107
    59
    Jun 21, 2016
    Manitoba, Canada
    The load based governor perameter may quite possibly be enabled
  4. Volvo8873
    240
    145
    Apr 27, 2016
    Western Wisconsin
    That would make sense. I have been trying to get VCADS loaded on my computer hopefully this week then I can check it.
  5. cumminskid123
    107
    59
    Jun 21, 2016
    Manitoba, Canada
    rule of thumb man, if the truck pulls good, coolant and oil aren't going low, fuel mileage is good, then essentially there is no REAL problem lol
  6. ryanbob1
    ryanbob1 Light Load Member
    121
    35
    Sep 9, 2016
    well you wont ever get as much turbo boost unloaded than loaded when loaded its haulin ###
  7. 51.50
    51.50 Heavy Load Member
    894
    1,943
    Jan 20, 2016
    Salem Oregon
    It's not broken. Don't " fix" it.
  8. Volvo8873
    240
    145
    Apr 27, 2016
    Western Wisconsin
    Well, found out that a couple exhaust manifold gaskets were leaking. Bought new ones, got home to install them and right away noticed a huge improvement obviously... found that "kick" when accelerating now. I actually had to turn down the setting on my blixxton today as it is too much.
    cumminskid123 Thanks this.
