2001 vnl64t drove truck about 100 miles shu it down
Then tried starting it and nothing check starter good got power
Got power to relay on firewall but when turn key no click
check all fuses and relays are good
Staring issues
Discussion in 'Volvo Forum' started by Vijay888, Aug 14, 2012.
Have someone try to start it and see if you see any sparks fly at the starter connection. A little corrosion and a hair loose and it will fail to turn even though every looks okay and tests 12V.
If that isn't it check the starter solenoid. -
tap the starter with a hammer......
Vijay888 Thanks this. -
Do you get power on the small wire on the starter solenoid when you turn the key?
Yes if I bypass the starter or the relay it will start but if I turn the key it does not even click but by turnin the key the power works on relay but does not turn over
Let me find wiring diagram. BTW, can you see N symbol on dashboard when starter not working?
Sounds like a bad connection between relay, and starter solenoid. If I understand correctly, ignition and starter is fine. Check the power on the ougoing side of relay.
Aaah! Stop staring at me! -
I believe there a short as well here is scenario the relay has 4 wires 2 blk 2 red 1 red continuous other nothing presume 1 blk is ground when key is turn on other blk light up so I'm guessing bad ground or something hoping to find wiring diagram
