Starter problem.
Discussion in 'Kenworth Forum' started by Rayl, Mar 30, 2018.
  1. Rayl
    Rayl Bobtail Member
    16
    16
    Dec 30, 2017
    Truck in my profile has a 3406a cat. Three new 12v batteries. Have voltage drop tested it and have less than a volt drop Truck was converted to 12 volt previously but looks to have the original starter. Truck is a very poor cranker. Warm or cold Would the original starter work on 12 ?
  3. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    Horribly slow if at all, plus the starter itself would tend to over heat without enough voltage if it was a 24 volt one.
    I have seen a few older trucks that were 24 volt start / 12 volt run.
    Uses a system of relays to swap battery positions to give 24 volts to the starter.
  4. swaan
    swaan Road Train Member
    2,942
    4,376
    Jul 12, 2009
    BC canada
    The truck had a A model cat that you think has the original starter and it cranks slow.!?
    Put a new starter in it. Could be a 24 v starter with only 12v going to it..
    Either way it's probley 35 years old if original.
    Get a 39mt delco.
    SAR Thanks this.
  5. Rayl
    Rayl Bobtail Member
    16
    16
    Dec 30, 2017
    All the batteries are connected in a way to have 12 volt total
    i guess I should rephrase. Have shop paper work when it was converted and it does not mention a starter. It does mention a solenoid and relay
  6. swaan
    2,942
    4,376
    Jul 12, 2009
    BC canada
    Well it's a no brainer.
    boneebone Thanks this.
