starter problems
Discussion in 'Volvo Forum' started by butterbean1977, May 5, 2014.
  1. butterbean1977
    butterbean1977 Bobtail Member
    15
    mississippi
    Does anyone know what I can check the starter will not turn over and I hear fuses clicking
  3. brysol01
    brysol01 Medium Load Member
    320
    460
    Nov 2, 2009
    Loose nut on the battery cable to the starter, or loose ground wire
  4. KWmech
    KWmech Light Load Member
    141
    40
    Jun 16, 2012
    Check to see if you have power from the key switch to the signal wire on the solenoid on the starter. Should have 12 volts with key in the crank position.
  5. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    Fuses don't click but yeah it sounds like a simple problem of a loose or corroded connection at the battery or starter. Make sure your connections are clean and tight. As little as an eighth of a turn on a corroded connection is enough to break contact. You either are hearing the starter relay or solenoid clicking. Sometimes poor starter connections will throw sparks if you look closely while someone turns the key. At night it's easy to see.
  6. butterbean1977
    15
    mississippi
  7. 70s_driver
    70s_driver Medium Load Member
    611
    358
    May 4, 2014
    The terminal post on the Solenoid had melted on mine causing it not to engage the starter. It had the voltage like kw said but come to find out the post had melted at the solenoid.
