Starting issues 2003 9400I
Discussion in 'International Forum' started by LeviTrucker, Sep 10, 2022.
  1. LeviTrucker
    LeviTrucker Bobtail Member
    34
    5
    Mar 24, 2022
    Need insight please I have a 9400I Eagle 2003. I shut my truck off and tried to start it up again it wouldn't start it was making clicking sounds. I thought it was the battery so I charged the battery up, put it back on the truck and turned the ignition on nothing same clicking noise. After couple times of siphoning on and off on the fourth time it started. Anyone know what could cause this issue? I’ve replaced the firewall solenoid,battery’s 6 months ago,alternator one year ago, Starter 2 years ago.
  3. 062
    062 Road Train Member
    6,328
    33,969
    Oct 20, 2013
    @God prefers Diesels had some sort of starter problem.
    Make sure all connections are clean and tight.
    God prefers Diesels Thanks this.
  4. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    One truck I had it was the main battery ground to the frame. Rusty nut on stud holding the cables was corroded.
  5. God prefers Diesels
    4,198
    22,265
    Jun 26, 2020
    South Texas
    It was two wires disconnected that went into the back of the starter for the thermal overload protection. The clip was broken, so I just butt-connectored them together.
    Banker and 062 Thank this.
  6. Heavyd
    Heavyd Road Train Member
    7,826
    6,276
    Feb 4, 2009
    I would put a test light to the solenoid wire at the starter and have the test light where I can see it and try cranking. If the light is coming on that means the starter is getting solenoid signal to crank, then you need to check main battery connections at both positive and ground. If those are good, then it is the starter. If you have no light then you are hearing the firewall solenoid clicking only and need to trace that trigger wire between the firewall solenoid and starter solenoid or run a new wire.
