starting issues
Discussion in 'Kenworth Forum' started by Adriantx, Aug 15, 2020.
  1. Adriantx
    Adriantx Light Load Member
    64
    17
    Dec 29, 2018
    Replaced starter and had everything checked also replaced all 4 batteries but my question is will a bad crankcase filter make the truck struggle to starting??
  3. cke
    cke Road Train Member
    6,164
    75,882
    Aug 4, 2013
    Colfax Wi
    No. Maybe bad wire going to the starter
    Ruthless and AModelCat Thank this.
  4. Adriantx
    64
    17
    Dec 29, 2018
    had everything checked twice by 2 shops and kenworth dealer was told nothing was found wrong
  5. Adriantx
    64
    17
    Dec 29, 2018
  6. clausland
    clausland Road Train Member
    1,933
    11,068
    Dec 5, 2014
    North Woods
    Crankcase filter?? When you say, struggle to start, do you mean turns over slow?
    Most of those problems are due to either high resistance or bad/insufficient ground. A big diesel requires amperage, lots of it and it needs to be free flowing.
    Batteries and starter are new? Check your battery cables and connections, proper gauge, check for corrosion hiding within the cables, ensure your grounds are clean and adequate.
  7. Adriantx
    64
    17
    Dec 29, 2018
    Truck cranks but won't start 2nd time dose the same ting only cranks 3rd time is when it starts only happens every now and then starter is new had fuel lines and cables checked by kenworth a 2 other shops was told nothing found wrong batteries are new replaced them not to long ago truck has power like normal no diming of lights dash lights up like new voltage shows above 13 when I cycle it oil pressure is good tanks are half full almost always was told it could be a bad relay but don't know which one it is
  8. Lowboy456
    Lowboy456 Light Load Member
    293
    140
    Mar 14, 2017
    Is it winding fast and taking a long time to start or winding slow?
    If its winding slow you might have a parasitic draw draining down the batteries when the truck is parked.
    Or a bad connection on one or more of the batteries or a weak alternator.
    I've seen weak alternators do right at 13V and they would work only until you need the head lights. Then there is simply not enough voltage to replace what the head lights take out.
    If its winding fast and taking a long time to start you might have a fuel related issue.
    Is it smoking white any once you get it running?
  9. AModelCat
    164,663
    13 volts is low. Should be seeing 13.5 to 14.5 volts from a good charging system.
  10. Adriantx
    64
    17
    Dec 29, 2018
    No it dosent start slow no white smoke at all alternator was checked and is good
  11. AModelCat
    164,663
    Helps if we knew more about this truck.........
