Static
Discussion in 'CB Radio Forum' started by Grouch, Sep 11, 2014.
  1. Grouch
    Grouch Road Train Member
    2,126
    4,409
    Feb 3, 2009
    Between here and eternity
    I am having a lot of static, but whenever I reach over and just touch the cb, the static stops. Any opinions??
  3. handlebar
    handlebar Heavy Load Member
    Hard to narrow down with the small amount of info supplied so far. But just for S&G, disconnect the antenna lead from the back of the radio and see if the same thing happens.
    Is the radio mounted tightly to chassis ground? Where are you getting power and ground for the radio from now? Is the noise always there, or only when engine running/wipers/fan motors/etc.
    And since we don't know anything about your radio experience yet, is the squelch set right at threshold, or all the way one way or the other?
    73
  4. Ridgeline
    22,730
    123,516
    take a piece of wire, find a ground somewhere in the truck and attach it from that ground directly to the radio - see what happens. It sounds like you have a floating ground issue with the radio. Any wire will work, even speaker wire.
  5. Grouch
    2,126
    4,409
    Feb 3, 2009
    The radio is in a Columbia, overhead in the hole that Freightliner designed for a CB. I turn the squelch to get rid of the static and then I don't get reception.
  6. Powder Joints
    7,988
    8,406
    Sep 25, 2007
    Rosamond, SoCal
    Ground, run a new to the frame, not the battery thats a separate issue
