steepest grade for driveway
Discussion in 'Ask An Owner Operator' started by 86scotty, Aug 2, 2020.
  1. 86scotty
    86scotty Road Train Member
    4,717
    12,953
    Aug 27, 2017
    Appalachia
    I'm looking at some rural land. The front driveway from road is way too small, steep and winding for a tractor. I do need to bring my tractor home most weekends but I have a paid spot for trailer a few miles away.
    There is a paved access road to the back of the land going up to a county water tower that I can use but it is steep. It starts about 6 or 7% but gets as steep as 14% in a spot or two. My twin screw tractor does have an axle lock.
    Think I'll have any problems bobtailing up that grade? Of course I know in winter I'll have to plan ahead. Total length is just about 300' and it is straight up, no turns.
    D.Tibbitt and Dave_in_AZ Thank this.
  3. Concorde
    Concorde Road Train Member
    5,482
    19,491
    Jun 29, 2016
    West Melbourne Florida
    I’ve been up 9% grades @ 80k with trailer in PA.. One I had to stop and go 1/2 way up..
    You can do it.
    D.Tibbitt, Dave_in_AZ and alds Thank this.
  4. MACK E-6
    50,067
    238,729
    Just get a running start. :)
    Coffey, okiedokie, AModelCat and 2 others Thank this.
  5. D.Tibbitt
    157,227
    Well in honor of @x1Heavy . We all know hes been up some 30% grades fully loaded and never had a problem. Im sure hes been up some 60% grades bobtail :D
  6. Atlaw4u
    Atlaw4u Heavy Load Member
    750
    1,131
    Jun 8, 2018
    I think you will be okay. It's probably more the condition of the road in inclement weather over the grade.
    I live on a remote spread at 8,600 feet elevation.
    My driveway is a mile long, fairly steep with some tight turns. I park my truck and flat at home except in the winter. Although I chain up and bring the truck home a few times during the winter.
    I did change to a more aggressive open shoulder drive which helps when it is wet or muddy. It wwill also help if you put down plenty of gravel for your parking spot.
    86scotty and D.Tibbitt Thank this.
  7. Dave_in_AZ
    425,637
    I got stuck on one Friday that went from flat to about a 47 degree incline.
    D.Tibbitt Thanks this.
  8. SmallPackage
    5,806
    18,600
    Dec 20, 2019
    Marion Texas
    As long as you have nothing to high center on you should be ok. You will get to excercise the low gear. One cool thing is if you ever loose battery power it will be easy to roll start the engine.
  9. Kshaw0960
    Kshaw0960 Road Train Member
    1,581
    5,025
    Jun 17, 2018
    Doing dirt for awhile opened my eyes to what a truck can really do. It’s absolutely insane how high of a grade you can go up. You’re fine.
    Coffey and not4hire Thank this.
  10. IH Truck Guy
    4,955
    57,552
    Mar 2, 2008
    Purgatory
  11. not4hire
    not4hire Road Train Member
    7,142
    26,957
    May 16, 2012
    Calgary
